We have read all expert and user reviews on the Pivot Vault. In summary, this is what cyclists think.
11 reasons to buy
- Pivot offers the Vault in two tiers: one Pro with Shimano GRX mechanical groupset and four Team with variations of SRAM Force AXS.
- Reviewers relish the balance of low-speed maneuverability and stable, confident handling at high speeds.
- Both testers say the Iso Flex seat tube insert and exposed seatpost help absorb bumps.
- The Vault can run 1x or 2x drivetrains with internal, external, or semi-integrated cable routing.
- A tester of the top-end Vault Team with carbon wheels says it climbs well thanks in part to the low weight (18.3lb in size S).
- One expert relishes the Pivot's versatility, saying it does almost everything "reasonably well."
- The Vault can take tires up to 50mm, a 40mm-travel suspension fork, and an internally routed dropper seatpost.
- The frame has three-pack mounts on the underside of the top tube and bosses for three bottle cages, fenders, and a top tube bag.
- Experts find the slight 11-degree flare of the Zipp SL 70 XPLR carbon bars (Team builds) comfortable.
- The Vault has frame-integrated storage with two bags. Testers find it easy to use.
- Pivot frames come with a limited lifetime warranty for the original owner.
4 reasons not to buy
- Two reviewers say the Vault runs large.
- One tester bemoans the lack of mounts on the fork.
- Testers find the 40cm handlebars too wide for a size XS frame.
- Experts are frustrated by the lack of size-specific components, such as the XXS and XS frames both having 40cm bars and sizes XXS to M having 170mm cranks.
The Pivot Vault is a gravel/adventure bike available in five builds across two tiers. The entry-level Pro comes with mechanical Shimano GRX 820; the four Team builds run variations of SRAM's Force AXS group. The top two builds have carbon wheels. Reviewers praise the ride comfort, balanced handling, and low weight for climbing. The wide tire clearance, suspension fork compatibility, and mounting options impress. The main complaint is the "goofy" frame and component sizing, particularly the overly wide bars. Nonetheless, experts deem the "capable" Vault a great bike.Expert Reviews
85/100 based on 2 rated expert reviewsReview: The New Pivot Vault Gravel Bike Is Boring and I Love It
Pivot Vault Gravel Bike Review: Understated Performance
1 hour ago
15 hours ago
