We have read all expert and user reviews on the Prevelo Alpha Zero. In summary, this is what cyclists think.
- Prevelo’s Alpha Zero is a 12” balance bike for little shredders.
- With 1.75” Kenda air-filled tires, the bike is capable of rolling over dirt and gravel.
- The Alpha Zero’s step-thru frame and low bottom bracket give riders additional stability for gliding and striding.
- A Tektro handbrake provides riders with adequate stopping power. It provides them with beginner braking skills as they prepare for a larger pedal bike.
- The bike’s seat post has a quick-release lever, making it easy to adjust.
- The Prevelo Alpha Zero has an adjustable seat that allows the bike to fit most riders between the ages of 18 months and 4 years.
- Capped bolts cover the axles on the wheel and protect little riders' legs from injury.
- The bike has a durable aluminum frame.
- A threadless headset and internally routed cables give the bike a clean appearance.
2 reasons not to buy
- The bike is expensive compared to other balance bikes.
- One expert found the brake cable easily pops out of place on the Alpha Zero. They suggest securing it out of the rider’s way with a zip tie.
The Prevelo Alpha Zero is designed for riders learning to balance, stride and brake. It has a durable aluminum frame. The bike's quick-release seat post makes it easy to adjust to fit riders from 18 months to 4 years old. Notable features that make the Alpha Zero stand out include an internally routed cable, capped bolts, a threadless headset and air-filled Kenda tires. These features do not come without a price, as the bike is expensive compared to others in its category.Expert Reviews
100/100 based on 1 rated expert reviewPrevelo Alpha Zero Review
Best Toddlers Bikes
3 hours ago
16 hours ago
