We have read all expert and user reviews on the Priority E-Coast. In summary, this is what cyclists think.
18 reasons to buy
- According to testers, the E-Coast’s upright ride position is both comfortable & chill.
- Reviewers like the “luxe, plush” seat.
- Experts see the E-Coast as an affordable option for a versatile e-bike.
- Testers say the E-Coast’s “powerful” motor allows it to climbs hills with ease.
- The E-Coast is available in stepover and step-through frame styles, to fit riders 5’0”-6’4”.
- Testers say the E-Coast’s throttle is “smooth and powerful”.
- Reviewers say bouyant 3” fat tires are comfortable and cushioning.
- Testers are happy with the 576Wh battery’s 60-mile max range. They like that it’s removable and lockable.
- Hydraulic brakes are “smooth but capable”, featuring lever-actuated motor cut-off.
- Reviewers praise the “classic”, “pretty”, “exclusive”, and “sophisticated” colorways.
- The belt drive is clean, low-maintenance, and rust-free. Reviewers laud the value.
- The E-Coast can be set to either Class 2 or 3 modes and the max. speed can be preset up to 28mph.
- As a coastal consideration, numerous components are rust-proof or rust-resistant.
- This rig rolls out with an integrated headlight and “brake sensing” taillight.
- The included rear rack holds up to 50lb of cargo.
- The E-Coast’s frame and fork are aluminum, prolonging longevity in salt air environs.
- Warranties: Frame + Fork (5 years), Components (2 years), Battery (700 Cycles).
- A sturdy two-legged kickstand keeps this beefy boy upright.
- A tester says pedal input has little impact on motor assistance at higher speeds.
- One tester says the aluminum frame and fork are “a bit jarring on bumps”.
- Two testers say the E-Coast’s rear-heavy weight is noticeable when lifting.
- The E-Coast’s battery and motor are not UL safety certified.
- One reviewer had problems with assembly. They complained that their front fender rubbed on turns, while their front brake required frequent adjustment.
- Despite riding a step-through frame, this tester had to stand on tip-toes when stopped.
With the Priority E‑Coast, there's at least one member of the exclusive ‘belt-drive beach cruiser e-bike club’. Swept-back bars and upright geometry create a relaxed ride position. Its single-speed drivetrain is clean and low-maintenance but can limit gear range and the bike’s sensitivity to pedal input. But for cruising, on level beachside terrain? It’s well-suited. Massive 3” tires counter the rigidity of a rust-resistant aluminum frame. It is back-heavy to lift. Riders can switch between Class 2 and 3 modes and set any maximum speed, leading one tester to recommend it to timid and beginner riders.Expert Reviews
85/100 based on 3 rated expert reviewsPriority E-Coast Review – Electric Beach Cruiser
Priority Bicycles E-Coast Review:
An E-Bike Made for Smooth Summer Cruising
Review: Priority E-Coast
Tested: The Priority E-Coast E-Bike
Priority E-Coast Electric Beach Cruiser Review
Best Beach Cruiser Bikes
9 hours ago
