How to Use a Quick Release Chain Link
Shows how to disconnect and reconnect two of the most common quick release chain links.
Today we’ll learn how to use a quick release chain link. There are two common link types, for which all you need is a good set of pliers.
Type 1
The first type of quick release link is found on BMX and single speed chains. There are three parts: one link plate with two chain pins attached, a plate with no chain pins that slides on the other side, and a clip that holds the link together once installed.
Disconnect Type 1
To disconnect this type of link, place one jaw of your pliers on the chain pin, and the other jaw on the open end of the clip. Then squeeze your pliers until the clip pops off. Then you can remove the outer plate and slide out the rest of the link.
Reconnect Type 1
To reconnect, simply reverse the process: slide in the link with the chain pins, place the outer plate on the other side, and then put the clip back in place. This time place one jaw of your pliers on the closed end of the clip, and the other jaw on the opposing chain pin. Then squeeze them together until the clip snaps into place.
Type 2
The second type of quick release link is found on multi-speed chains. There are only two parts to this style. Each of the two plates are identical, and each has a chain pin on one end.
Disconnect Type 2
To disconnect this style, simply place the pliers on opposing ends of the link as demonstrated, and then squeeze the pliers together until you hear a click. Now you can slide both links out.
Reconnect Type 2
To reconnect this type you don’t even need any tools. Simply slide both ends of the link together and then rotate your chain on the bike until the quick release is on top and the pedal is facing forward. With both wheels on the ground, compress your brakes so your bike doesn’t move. Then step down on the pedal. It doesn’t take that much pressure to pull the links so they snap into place.
Related Links
Recommended Tools
- Park Tool CT-5 Chain Tool
- Park Tool CT-3 Chain Tool
- Park Tool CC-3.2 Chain Checker
- Park Tool CC-2 Chain Checker
Categories
Front derailer not moving
Latest post 2 days agoHi, I been upgrading my old bike with new brake and shift cables. I got my brakes working and now trying to get my shift cables working. I was able to install new shift cable, I made sure to hold the cable tight and tighten the Bolt to keep in place. But it doesn't move the derailer at all when shifting. I have a feeling it's a simple fix that I'm missing something. I thought it might be the new ...
Read moreWhat are the best cost effective ways to prevent chain rust?
Latest post 3 days agoI live 5 km from the ocean (not sure if that's relevant), and I pretty much only mountain bike. After every ride, I hose down and clean my bike. I wipe them down with a cloth. After a few days, the ones not ridden have what looks like surface rust appear on the chain. Do you have any cost-effective remedies to solve this issue?...
Read moreHow to deal with rusty chain
Latest post 5 days agoThe best thing is not to let your chain get rusty in the first place. Chains for most 6,7,8 speed bikes can be had for $15 to $20 all day long. For me my first choice is to just replace it and the reason is simple. If finished it does not meet the level of 95%+ perfect it will get replaced. If the chain you are trying to save does not have a quik link then that is an extra cost to figure...
Read moreRear v-brake repair
Latest post 4 weeks agoHi everyone, I'm new here and I've been trying to avoid taking my bike to a mechanic and save some money. I succesfully fixed my front but struggle with the rear, I got new brakes for the rear. I notice i think it might be the housing causing the noodle to be off centered and making the left brake pad to close to the rim. Any help would be greatly appreciated, thanks!! My next project is to attemp...
Latest post 2 months agoHello, Not sure if I should post this in buying advice or repairs, but here we are. I recently bought Schwinn cruiser an old one and I can't find the rear dropout bracket replacement. So I decided to try out a custom bike part manufacturer. Still waiting for my part, so if anyone has tried out a custom on demand manufacturer, please share your experience....
Latest post 2 months agoI have a Gazelle Esprit belt drive bike with hub gears which has a rear puncture. Can someone advise me on how to remove and refit the wheel? I'm aware that it can be quite complicated, but I have no option other than tackling it myself. The photos were taken with the bike upside down. IMG_20250122_105320.jpg (Size: 77.51 KB / Downloads: 54) IMG_20250122_105428.jpg (...
Latest post 3 months agoCan anyone advise what type of replacement jockey wheel I need for a 10 speed Red rear mech (it's got 11 teeth)? Bonus points if it's a link to a cheap (ish) one! Thanks...
Read moreGrip Shifters
Latest post 3 months agoCurrently renovating a child's bike. It has 24 inch wheels and is a suitable size for a 7-10 year old. Anyway it has grip shifters. it is a six speed with three chain rings on the front derailleur. On the rear derailleur the shifter does not appear to move the gear cable at all when shifting from 6 to 5 and 5 to 4. I am actually holding the cable with my finger and thumb against the cable cas...
Latest post 3 months agoAll of my bikes are 7 or 8 speed and sometime in the past I bought a 9 speed chain for some unremembered reason. is there any reason not to use it on an 8 speed bike?...
Latest post 4 months agoHello - new owner with an How to Operate the bike question. Hopefully, this is easily answered I Bought this bike a few weeks ago - Tested many bikes and finally landed on this particular Santa Monica. However, got busy with Christmas shopping, Life, and not so great weather days distracted me from riding. I also test drove so many that I forgot how to operate it.... I "thought" I remembered, ...
Latest post 4 months agoMy Trike.jpg (Size: 57.65 KB / Downloads: 53) Wife Trike.jpg (Size: 60.74 KB / Downloads: 53) Although I have ridden bikes on and off since a kid (75 years old now), I have very little experience with anything other than a single speed bike. I recently purchased a new 7-speed Gospel adult tike, which needed assembly. My wife has the same model trike but older and p...
Latest post 4 months agoI'm curious—how often or after how many miles do people typically check or change their mechanical disc brake pads? I've been bikepacking for a while but never really followed a maintenance schedule. A few weeks ago, I took my bike to a mechanic because I heard some noise. The mechanic did a quick overhaul, and I was sent on my way. However, a few weeks later, while descending steep hills, I s...
Latest post 5 months agoMy wife's road bike has Shimano Sora shifters with a triple front derailleur (stock). The thumb switch on the front shifter is VERY hard to use and she can't do it when she's riding. I did a full adjustment of the front derailleur but it didn't change anything. One thing that I noticed is that the shifter works smoothly when the shifter cable is unattached from the derailleur, suggesting that the ...
Read more
