Rad Power Bikes RadCity 3 Step-Thru
64/100
6 Hours
45 Miles
40 Nm
48V 14Ah
65.0 lb
We have read all expert and user reviews on the Rad Power Bikes RadCity 3 Step-Thru. In summary, this is what cyclists think.
21 reasons to buy
  • The RadCity 3’s step-through design makes for easy mounting and dismounting.
  • With 7 gears, a throttle and pedal-assist, the RadCity 3 climbs hills well.
  • The Rad Power RadCity Step-Thru 3 is an affordable option for beginners.
  • Reviewers are impressed with the bike’s 45-mile maximum range.
  • Regenerative braking helps to reclaim battery power upon slowing.
  • Testers enjoy this bike’s comfortable and upright ride position.
  • A 100mm suspension fork reduces bump discomfort on rough pavement.
  • With an adjustable stem & handlebar, this bike adjusts to fit most riders.
  • The RadCity 3’s battery is removable for security or off-bike charging.
  • Reviewers are delighted by Rad Power’s use of Samsung battery cells.
  • RadCity 3 riders have access to an independent throttle.
  • A backlit display shows speed, trip distance, remaining charge and wattage.
  • Reviewers complimented the quiet operation of the RadCity Step-Thru 3’s motor.
  • Riders can recharge devices using the USB port on the bike’s display.
  • A Velo Plush saddle is comfortable and features a handle to assist lifting.
  • The RadCity 3 is available in either black or white.
  • An integrated rear rack carries up to 60lb of cargo.
  • The RadCity Step-Thru 3 comes equipped with front and rear fenders.
  • An integrated headlight and taillight/brake-light are both included.
  • Step-Thru 3 owners are provided with a solid kickstand.
  • The RadCity 3 does feature bosses to attach a water bottle cage.
11 reasons not to buy
  • At 65lb, this e-bike is lighter than some competing models but is still heavy to lift.
  • A mechanic sees this bike’s derailleur, tires and pedals as low-end and ‘cheap’.
  • The bike's geared drivetrain and mechanical brakes require regular maintenance.
  • Some reviewers say the RadCity 3 doesn’t climb well with its ungeared motor.
  • The RadCity 3’s proprietary parts may be difficult to find replacements for.
  • A low-cost suspension fork adds significant weight to the RadCity 3.
  • Thumb-shifters aren’t the easiest to use when changing gears.
  • One mechanic is disappointed that the bike is fitted with mechanical brakes.
  • The RadCity 3 Step-Thru’s weight is centered toward the rear of the bike.
  • An owner’s bike reacted erratically after plugging a phone into the USB port.
  • The bike’s hub motor creates some ‘magnetic drag’ whilst freewheeling.
This is the step-through version of the third generation of Rad Power’s RadCity urban/commuter bike. The newest step-through RadRover features hydraulic brakes and massive ‘float-anywhere’ tires, but the RadCity 3 sticks to moderate tires, mechanical disc brakes and a more accessible price bracket. While braking and gearing components are mid-range (at best), they can be more easily maintained by owners than hydraulic brakes and internal hub options. It seems to be heavy for many owners to lift by themselves. But otherwise, owners are pleased with the price, seating position, power and range of the RadCity Step-Thru 3.
64/100 based on 1 rated expert review
RadCity 3 Step-Through Review
This definitely makes for a good commuting e-bike. On universality, it scored 10/10. This bike is built for pretty much any rider, with its low-sweep Step-Thru 3 frame.
Electric Bike Review
Rad Power Bikes RadCity Step-Thru 3 Review
A feature-complete, approachable step-thru, comfort-oriented, hybrid electric bicycle with regenerative braking. Only available in one size and the frame isn’t as stiff as the high-step, but it does come in two colors!
Rad Power Bikes RadCity Step-Thru 3 Electric Bike Review Part 2: Ride & Range Test
Overall, the Rad Power Bikes RadCity is a fun and easy-going step-thru eBike that is well equipped for the daily commute and weekend rides.
Rad Power RadCity Step-Thru Electric Bike Review
This is a fun, easy bike to ride. Riders of all ages and abilities can enjoy the RadCity, especially the step-thru design. It doesn’t feature some of the high-end components, but it does combine quality and function for a solid feel and awesome price point. This is a great starter bike.
Trespass My Eyes
2019 RadCity Step-Thru – 700+ Mile Review
I think I did around 200 miles, the derailleur came apart… Overall, the bike’s been really good.
Carmel MUP Rider
Why I Chose the RadCity Step-Thru 3
For the price-point and the value you get, you just can’t go wrong.
Detroit Love
RadCity Step-Thru 3 by Rad Power Bikes for the Wife
Really strong, solid bike. It is a heavy bike… getting up and down stairs is definitely going to be a little work, but it’s doable.
RadCity Step-Thru 3 Review: This Affordable Ebike Is Your Next Obsession
The RadCity Step-Thru 3 is practical, easy to use and great-looking to boot. If you’re ready, give an electric bike a try. This reasonably priced hybrid bike is the perfect place to begin.
The Rad Power RadCity Is the Affordable E-Bike That Can Change Your Life
The Rad Power RadCity, however, arrives ready to change the way you travel for significantly less than its competition—you could get a half-dead Saturn sedan at this price.
Review: The RadCity Electric Commuter Bike Is Truly ‘Rad’
I found my actual riding experience on the RadCity bike to be nothing short of thrilling. Rad Power Bikes’ engineering team deserves kudos for the suspension and gearing system — it is pleasantly smooth, and ideal for long city rides.
Rad Power Bikes RadCity Step-Thru 3 Electric Bike Review Part 1 – Pictures & Specs
The RadCity Step-Thru is a comfortable eCommuter bike with the easy get-on-and-ride step-thru frame, high capacity 48V 14ah lithium battery, 750-watt motor, disc brakes, and a lot of accessory options.
87/100 based on 6 ratings
    67%
    33%
Rad Power Bikes RadCity 3 Step-Thru in comparison to averages
64
