Rambo The Pursuit
91/100
35 Miles
120 Nm
48V 14Ah, 48V 10.4Ah
63 lb
We have read all expert and user reviews on the Rambo The Pursuit. In summary, this is what cyclists think.
7 reasons to buy
  • The Pursuit’s 750W mid-drive Bafang motor outputs a peak wattage of 1000W and is plenty powerful at hauling cargo and climbing hills.
  • A GTMRK suspension fork dampens bumps under the Pursuit’s front end.
  • Gearing is clean and internal, via the Pursuit’s Sturmey-Archer 3-speed rear hub.
  • A thumb-operated trigger throttle is available to Pursuit riders.
  • The Pursuit’s LCD display shows trip distance, battery level, power, and speed.
  • Stopping power is provided by 2-piston hydraulic disc brakes.
  • Kenda Krusade 26” x 4.0” fat tires provide the Pursuit with comfort and suspension over various surfaces.
3 reasons not to buy
  • Owners said the 63lb Pursuit was heavy to lift.
  • An owner received their Pursuit with a damaged fork.
  • The Pursuit’s brakes and suspension fork are manufactured by little-known brands.
The Rambo Pursuit is an electric hardtail fatbike with 26” wheels and large 4.0” tires. Like Rambo’s other bikes, it’s geared toward hunting but can be used for any off-road adventure. The Pursuit is also geared by a 3-speed Sturmey-Archer hub, which keeps the mechanics internal and avoids the need for a rear derailleur. The Pursuit’s 750W Bafang mid-drive motor can output a peak wattage of 1000W and a maximum 120Nm of torque. It’s fitted with a 48V 14Ah battery that provides riders with a purported maximum range of 35 miles. Hydraulic brakes are supplied by a company called Logan, while the fork is Rambo’s standard unit from manufacturer GTMRK. The bike is not the most expensive but it also ain’t cheap. Older models are fitted with a 10.4Ah battery.
96/100 based on 43 ratings
    84%
    14%
    2%
#69 Best Electric
Top 20%
#8 Best Hunting
Top 30%
#4 Best Rambo Bike
Bottom 40%
#132 Best of All Bikes
Top 20%
Rambo The Pursuit in comparison to averages
