Rambo The Venom
95/100
40 Miles
30 mph
1000 W
160 Nm
48V 17Ah
71 lb
We have read all expert and user reviews on the Rambo The Venom. In summary, this is what cyclists think.
  • The Venom’s 1000W Bafang mid-drive motor delivers 1500W at peak power.
  • The Venom is equipped with Rohloff’s excellent 14-speed rear hub.
  • With a 48v 17Ah battery, the Venom delivers a maximum 40 miles of range.
  • The Venom’s Bafang motor achieves a maximum 160Nm of torque, making it a powerful climber.
  • Tektro 4-piston hydraulic brakes prove capable when stopping this beefy bike.
  • With a payload of 300lb, the Venom can easily carry a rider, cargo and game.
  • The Venom is equipped with throttle-on-demand.
  • Rough terrain is no issue for the Venom, with huge Maxxis Minion 26”×4.8” tires.
  • With Rambo’s ‘TrueTimber VSX’ camouflage colorway, the Venom blends into the woods.
  • The Venom is supplied with a full-color display.
3 reasons not to buy
  • The Venom is only available in a single, 19.7” frame size.
  • At 71 lbs, the Venom is heavy.
  • The Venom's suspension fork is built by the little-known GTMRK brand.
Rambo’s Venom is a powerful electric fatbike with a wide gear range. It's well-suited to off-road adventures and, with its camouflage colorway, for hunting. The Venom boasts a 1000W mid-drive Bafang motor that can output 1500 watts at peak power. The Venom is equipped with powerful Tektro 4-piston hydraulic brakes, front (203mm disc) and rear (180mm). The most surprising of the Venom’s components is the renowned Rohloff 14-speed internal hub. This high-end hub has a 526% gear range while keeping the bike's gears protected from the elements. The Rambo Venom rolls on gigantic 26” x 4.8” tires, making it a backwoods beast. At this price, it’s somewhat unexpected that the Venom’s suspension fork comes from the lower-end GTMRK brand. The bike is available in one 19.7” frame size and weighs 71 pounds. Rambo’s Venom is a mostly high-end fatbike with a high-end asking price.
100/100 based on 42 ratings
Rambo The Venom in comparison to averages
