How to Recondition RapidFire Plus Shifters
Shows how to troubleshoot, clean and lubricate RapidFire-style index shift levers.
In today’s tutorial, we’ll learn how to troubleshoot and repair a RapidFire Plus style index shifter. For this job you’ll need a phillips(+) screwdriver, a 4 or 5mm allen key, some light oil, spray grease, and some penetrating fluid like liquid wrench or WD-40.
Sometimes nothing happens if you try to shift up to an easier gear, or down to a harder gear. If your cables are functioning smoothly, this likely means that there is either a build up of gunk on the inside of your shifter, or that some of the internal parts are worn or broken.
Try This First
If it’s just gummed up, sometimes you can get it working again by squirting some light oil inside, and then running through the gears several times to make sure the oil fully penetrates the internal parts.
Look Inside
If not, you’ll have to remove the outer casing and take a look inside. Keep in mind that there are many different styles of these shifters but the concept is generally the same. You don’t want to remove all of the screws on the shifter as there are many small springs and moving parts that are difficult to put back together. Try and see which screw looks like it removes only the dust cover.
With the cover removed, you should see a ratcheting mechanism that includes a gear and a spring loaded pawl. If you run through the gears while looking inside, you’ll see that every time you shift up to an easier gear the pawl pushes against the gear until it clicks it into the next position. This builds tension on the spring and pulls the cable a set amount, which moves your derailleur up one sprocket.
When you use the index lever to shift the derailleur down into a harder gear, the spring releases and causes the gear to slip back one position. This releases the cable a set amount, which pulls your derailleur down one sprocket.
Further Repair
If either of these functions is not happening, inspect the gears and pawls to make sure nothing is broken or looks worn. If they are, you’ll usually just have to replace the shifter. If everything looks fine but the shifter still doesn’t work, you can give it a bit of an overhaul to clean and re-lubricate the inner mechanism.
Disassemble Shifter
You’ll have to remove the shift cable first. It’ll usually slide out the of the shifter when it’s in the highest gear (7,8,9). Then remove the shifter body from your handlebar using the top allen bolt. Unscrew and remove the barrel adjuster and then remove any remaining screws until you can pull apart the dust covers and slide the inner mechanism out. Make sure you pay attention to how everything came apart so you can get it back together again.
Reassemble Shifter
Soak the unit with some penetrating fluid and then wipe it down and let it air dry. Once dry, spray some grease in between all of the moving parts and then re-assemble the shifter parts the same way they came apart. Mount it back on the handlebar and click through all of the gears so the spray grease penetrates. Then replace the shift cable and adjust your derailleur as needed.
If you’ve tried all of these steps and the shifter still doesn’t work, unfortunately it’ll likely need replacing.
Related Links
Recommended Tools
- Park Tool HXS-1.2 Hex Wrench Set
- Park Tool Wrench Combo Set
- Park Tool SD-Set Shop Screwdrivers
- Tri-Flow Superior Lube
Categories
Latest post 6 days agoI live 5 km from the ocean (not sure if that's relevant), and I pretty much only mountain bike. After every ride, I hose down and clean my bike. I wipe them down with a cloth. After a few days, the ones not ridden have what looks like surface rust appear on the chain. Do you have any cost-effective remedies to solve this issue?...
Read moreRear v-brake repair
Latest post 2 weeks agoHi everyone, I'm new here and I've been trying to avoid taking my bike to a mechanic and save some money. I succesfully fixed my front but struggle with the rear, I got new brakes for the rear. I notice i think it might be the housing causing the noodle to be off centered and making the left brake pad to close to the rim. Any help would be greatly appreciated, thanks!! My next project is to attemp...
Latest post 1 month agoHello, Not sure if I should post this in buying advice or repairs, but here we are. I recently bought Schwinn cruiser an old one and I can't find the rear dropout bracket replacement. So I decided to try out a custom bike part manufacturer. Still waiting for my part, so if anyone has tried out a custom on demand manufacturer, please share your experience....
Latest post 1 month agoI have a Gazelle Esprit belt drive bike with hub gears which has a rear puncture. Can someone advise me on how to remove and refit the wheel? I'm aware that it can be quite complicated, but I have no option other than tackling it myself. The photos were taken with the bike upside down. IMG_20250122_105320.jpg (Size: 77.51 KB / Downloads: 51) IMG_20250122_105428.jpg (...
Read moreGrip Shifters
Latest post 3 months agoCurrently renovating a child's bike. It has 24 inch wheels and is a suitable size for a 7-10 year old. Anyway it has grip shifters. it is a six speed with three chain rings on the front derailleur. On the rear derailleur the shifter does not appear to move the gear cable at all when shifting from 6 to 5 and 5 to 4. I am actually holding the cable with my finger and thumb against the cable cas...
Latest post 3 months agoAll of my bikes are 7 or 8 speed and sometime in the past I bought a 9 speed chain for some unremembered reason. is there any reason not to use it on an 8 speed bike?...
Read moreTrek domane tyre
Latest post 6 months agoRecently bought a slightly used 26" meridian trike. While replacing wider tires on the rear, I noticed an issue with the rear drive side wheel hub. The wheel is held on with a nut and single washer. The hub is not held firmly in a location on the axle and is able to slide back and forth on the axle a good half inch even though the nut is tightened all the way down to its bottom threads on the axle...
Read more
