How to Replace Cable Housings
Measure, cut, lubricate and replace your old seized or damaged cable housings.
If your cable housing is old and stiff, or damaged, it’s a good idea to replace them to improve your braking and shifting. So how do you know how much length you will need? It’s easy if your old cables are still attached as you can simply measure them, but sometimes you’ll need to measure them manually.
Materials
It’s quite difficult to evenly cut cable housings with regular pliers, so I’d recommend picking up a proper cable cutter before you begin. However, you will need some regular cutters on hand to cut off any sheared spiral housings, and a scribe or some kind of sharp poking device is handy to poke out the inner lining clear. You’ll also need to install ferrules on each end of your housing, so you’ll need two for each section of housing.
Types of Housing
It’s also very important to know that there is a big difference between brake and shift housings. Brake cable housings have a coiled metal spiral embedded in them, while compressionless shift cables have a series of tiny round wires running parallel along the length of housing. If you were to use brake cable housings on shift cables the result would be very poor shifting.
Calculating Length
As I mentioned before, if your old housings are intact you can simply take them off and measure them for the exact replacement length. However, if there are no existing housings, you’ll have to buy more than you think you’ll need and then trim it down. For example, if I needed to replace the rear derailleur housing, I would take a ruler and move it along the estimated path and then add another few inches just to be safe.
Housings should make a smooth curve, with no sharp bends. For example, the length shown here is ideal. This would be too short, and this would be too long. The sections that run from your handlebar to your frame shouldn’t be too long, but there should be enough room to turn the handlebar all the way in both directions.
Cutting Cables
Once you’ve measured twice, cut the housing clean across using the cable cutter. The inner spiral on brake housings will sometimes shear leaving some metal poking out. Trim this with your wire cutters until the end is flush. Then clear a hole in the plastic lining with your poker. Shift cables usually cut clean and just need the lining poked through.
Installation
Once all of your housing sections are cut and trimmed, slide a ferrule on the end of each. I like to also squirt a drop of Tri-Flow into the housings to keep them operating smoothly. Now you’re ready to install the housings and reinstall the inner cables. I’ll demonstrate how to replace your inner cables in an upcoming tutorial.
Related Links
Recommended Tools
- Shimano TL-CT10 Cable Cutter
- Tri-Flow Superior Lube
- Park Tool HBH-2 Handlebar Holder
- Park Tool SA-3 Heavy Duty Shop Apron
Categories
Rear v-brake repair
Latest post 2 weeks agoHi everyone, I'm new here and I've been trying to avoid taking my bike to a mechanic and save some money. I succesfully fixed my front but struggle with the rear, I got new brakes for the rear. I notice i think it might be the housing causing the noodle to be off centered and making the left brake pad to close to the rim. Any help would be greatly appreciated, thanks!! My next project is to attemp...
Latest post 3 weeks agoHello, Not sure if I should post this in buying advice or repairs, but here we are. I recently bought Schwinn cruiser an old one and I can't find the rear dropout bracket replacement. So I decided to try out a custom bike part manufacturer. Still waiting for my part, so if anyone has tried out a custom on demand manufacturer, please share your experience....
Latest post 4 weeks agoI have a Gazelle Esprit belt drive bike with hub gears which has a rear puncture. Can someone advise me on how to remove and refit the wheel? I'm aware that it can be quite complicated, but I have no option other than tackling it myself. The photos were taken with the bike upside down. IMG_20250122_105320.jpg (Size: 77.51 KB / Downloads: 48) IMG_20250122_105428.jpg (...
Latest post 1 month agoHi everyone! I hope you're enjoying a great start to 2023. I'm curious to hear your go-to method for getting a chain truly clean. I don't mean, just looks shiny or is good enough for a quick clean after a ride. I want to know what you do when you want to get every last morsel of ground-up, link-destroying, roller-eating, tooth-gnashing crud out of your chain. The Best Chain-Cleaning Recipe Ever?...
Latest post 2 months agoHello - new owner with an How to Operate the bike question. Hopefully, this is easily answered I Bought this bike a few weeks ago - Tested many bikes and finally landed on this particular Santa Monica. However, got busy with Christmas shopping, Life, and not so great weather days distracted me from riding. I also test drove so many that I forgot how to operate it.... I "thought" I remembered, ...
Read moreGrip Shifters
Latest post 3 months agoMy Trike.jpg (Size: 57.65 KB / Downloads: 48) Wife Trike.jpg (Size: 60.74 KB / Downloads: 48) Although I have ridden bikes on and off since a kid (75 years old now), I have very little experience with anything other than a single speed bike. I recently purchased a new 7-speed Gospel adult tike, which needed assembly. My wife has the same model trike but older and p...
Latest post 4 months agoI recently bought a 7-speed bicycle practically brand new it still has a little rubber nipples on the tires apparently it got backed into in the garage and it bent the rear rim sideways my question is can I go out and buy another just like single speed 20 inch bicycle and put the 7-speed cassette onto that rim?...
Read moreTrek domane tyre
Read moreBianchi Oltre Pro Garmin Mount
Latest post 5 months agoI am wondering if anyone can help me with the garmin mount that came with my recently purchased Bianchi Oltre Pro. I was on a ride descending and the mount flew off, landing in the middle of the road with my garmin head unit. Luckily the head unit still works with a few minor scratches and cracks. From the picture you can see that it was not that the screws came loose, it was in fact the part of ...
Read more
