How to Replace Your Chainrings
Basic removal and installation instructions for 5-bolt chainrings on 3-sprocket systems.
This tutorial will demonstrate how to remove and install chainrings. Since there are so many different crank and chainring sizing combinations, I’ll stick to the basics and give a general overview of the process based on a 5-bolt, 3-chainring system.
For this job, you’ll typically need a 5mm allen key, a chainring nut wrench, and some waterproof grease. On some bikes, you may find it easier to remove the right crank arm before you begin.
Chainring Removal
Before removing the largest two chainrings you’ll often have to remove the smallest one, which is often threaded directly into your crank arm. Use your allen key to loosen all of the bolts that hold the chainring in place, and then use a marker to make a note of the chainring’s position in relation to the crank before removing it completely. Some chainrings have a bump sticking out that should be lined up with your crank arm.
The largest two rings are usually bolted to each other with a nut and bolt. Here you’ll need to hold the nut in place with the special chainring wrench while you loosen the bolt with your allen key. Once again it’s a good idea to mark the chainring’s position in relation to your crank arm. The two largest outer rings often have a few spacers or washers in between, so be sure to note exactly how they came apart so they can be reinstalled correctly.
While it’s ok to install a new chainring that has a different number of teeth, you’ll want to make sure that your new chainrings have the same side profile as the old ones.
Chainring Installation
Before you reinstall the bolts, apply a thin layer of grease to the threads to keep out moisture. Now you can reassemble all of your chainrings the same way they came apart.
Make sure all of the bolts are finger tight and then begin tightening them evenly in a star pattern. Start by tightening the first bolt, and then every second bolt until you’ve gone all the way around. Repeat this process until all of the bolts are tight. Be careful not to over-tighten. Park Tools recommends 44-88 inch pounds of torque for aluminum bolts, and 70-95 inch pounds for steel bolts.
Related Links
Recommended Tools
- Shimano TL-FC20 Dustcap Pin Tool
- Park Tool HXS-1.2 Hex Wrench Set
- Shimano TL-FC10 Crank Extractor
- Park Tool PAW-12 Adjustable Wrench
Categories
Latest post 4 days agoI live 5 km from the ocean (not sure if that's relevant), and I pretty much only mountain bike. After every ride, I hose down and clean my bike. I wipe them down with a cloth. After a few days, the ones not ridden have what looks like surface rust appear on the chain. Do you have any cost-effective remedies to solve this issue?...
Read moreRear v-brake repair
Latest post 1 week agoHi everyone, I'm new here and I've been trying to avoid taking my bike to a mechanic and save some money. I succesfully fixed my front but struggle with the rear, I got new brakes for the rear. I notice i think it might be the housing causing the noodle to be off centered and making the left brake pad to close to the rim. Any help would be greatly appreciated, thanks!! My next project is to attemp...
Latest post 1 month agoHello, Not sure if I should post this in buying advice or repairs, but here we are. I recently bought Schwinn cruiser an old one and I can't find the rear dropout bracket replacement. So I decided to try out a custom bike part manufacturer. Still waiting for my part, so if anyone has tried out a custom on demand manufacturer, please share your experience....
Latest post 1 month agoI have a Gazelle Esprit belt drive bike with hub gears which has a rear puncture. Can someone advise me on how to remove and refit the wheel? I'm aware that it can be quite complicated, but I have no option other than tackling it myself. The photos were taken with the bike upside down. IMG_20250122_105320.jpg (Size: 77.51 KB / Downloads: 51) IMG_20250122_105428.jpg (...
Read moreGrip Shifters
Latest post 3 months agoAll of my bikes are 7 or 8 speed and sometime in the past I bought a 9 speed chain for some unremembered reason. is there any reason not to use it on an 8 speed bike?...
Read moreTrek domane tyre
Latest post 6 months agoRecently bought a slightly used 26" meridian trike. While replacing wider tires on the rear, I noticed an issue with the rear drive side wheel hub. The wheel is held on with a nut and single washer. The hub is not held firmly in a location on the axle and is able to slide back and forth on the axle a good half inch even though the nut is tightened all the way down to its bottom threads on the axle...
Read more
