important: Nuts and bolts on your bike should always be tightened to the manufacturer's specifications.
How to Replace a Freewheel
Demonstrates how to remove and install a traditional thread-on freewheel cluster.
Video updates
  • 01:21 - Apply a thin layer of grease to the hub threads before installing the freewheel.
In this tutorial we’ll learn how to remove and install a freewheel on your bike. You may remember a while back when we covered cassette removal and installation. For this job you’ll need a notched freewheel remover and a large wrench or vise clamp.
Here’s how the two systems differ: a cassette is a series of gears that slides onto a freewheel unit. This is a better system because it allows you to replace worn sprockets without having to replace the freewheeling component (freehub body). A freewheel on the other hand, contains both the sprockets and freehub in a single unit that threads onto the outer flange of your hub. We’ll be covering removal and installation of this style today.
Click on this image to visit Sheldon Brown’s page on this topic:
Cassette Freewheel
Freewheel Removal
First you’ll have to remove the rear wheel from your bike. Then in some rare cases the axle nuts will be too big to allow the freewheel tool to slide into the freewheel, so you’ll have to overhaul the hub to remove them first. Now slide the freewheel remover into the freewheel and loosen it with your large wrench by holding the wheel on the firmly on the ground and turning your wrench counter clockwise.
If your freewheel is really tight, you may need to mount the tool in a vise clamp so that you can use the wheel as leverage. I don’t have a clamp to demonstrate this, but once mounted in the vise, you can easily turn the wheel counter-clockwise to loosen the freewheel.
Freewheel Installation
Before installing the new freewheel, inspect the threads on the hub to make sure they aren’t damaged. Be careful threading the new freewheel on, as you don’t want to cross-thread it. If it feels unusually tight right away, back the freewheel off and try again until it threads on smoothly.
Tightening
To tighten a freewheel, all you have to do is get it finger tight and then re-install your wheel and go for a ride. The freewheel will tighten itself while you’re pedaling!
Related Links
Recommended Tools
Categories
I live 5 km from the ocean (not sure if that's relevant), and I pretty much only mountain bike. After every ride, I hose down and clean my bike. I wipe them down with a cloth. After a few days, the ones not ridden have what looks like surface rust appear on the chain. Do you have any cost-effective remedies to solve this issue?...
Read more
Rear v-brake repair
Latest post 2 weeks ago
Hi everyone, I'm new here and I've been trying to avoid taking my bike to a mechanic and save some money. I succesfully fixed my front but struggle with the rear, I got new brakes for the rear. I notice i think it might be the housing causing the noodle to be off centered and making the left brake pad to close to the rim. Any help would be greatly appreciated, thanks!! My next project is to attemp...
Read more
Custom Bike part manufacturing
Latest post 1 month ago
Hello, Not sure if I should post this in buying advice or repairs, but here we are. I recently bought Schwinn cruiser an old one and I can't find the rear dropout bracket replacement. So I decided to try out a custom bike part manufacturer. Still waiting for my part, so if anyone has tried out a custom on demand manufacturer, please share your experience....
Read more
I have a Gazelle Esprit belt drive bike with hub gears which has a rear puncture. Can someone advise me on how to remove and refit the wheel? I'm aware that it can be quite complicated, but I have no option other than tackling it myself. The photos were taken with the bike upside down.   IMG_20250122_105320.jpg (Size: 77.51 KB / Downloads: 51)   IMG_20250122_105428.jpg (...
Read more
Hi everyone! I hope you're enjoying a great start to 2023. I'm curious to hear your go-to method for getting a chain truly clean. I don't mean, just looks shiny or is good enough for a quick clean after a ride. I want to know what you do when you want to get every last morsel of ground-up, link-destroying, roller-eating, tooth-gnashing crud out of your chain. The Best Chain-Cleaning Recipe Ever?...
Read more
What jockey wheel Red 10 Speed
Latest post 2 months ago
Can anyone advise what type of replacement jockey wheel I need for a 10 speed Red rear mech (it's got 11 teeth)? Bonus points if it's a link to a cheap (ish) one! Thanks...
Read more
Grip Shifters
Latest post 3 months ago
Currently renovating a child's bike. It has 24 inch wheels and is a suitable size for a 7-10 year old. Anyway it has grip shifters. it is a six speed with three chain rings on the front derailleur. On the rear derailleur the shifter does not appear to move the gear cable at all when shifting from 6 to 5 and 5 to 4. I am actually holding the cable with my finger and thumb against the cable cas...
Read more
9 speed chain on 8 speed bike
All of my bikes are 7 or 8 speed and sometime in the past I bought a 9 speed chain for some unremembered reason. is there any reason not to use it on an 8 speed bike?...
Read more
Operation of Santa Monica Ebike
Hello - new owner with an How to Operate the bike question. Hopefully, this is easily answered I Bought this bike a few weeks ago - Tested many bikes and finally landed on this particular Santa Monica. However, got busy with Christmas shopping, Life, and not so great weather days distracted me from riding. I also test drove so many that I forgot how to operate it.... I "thought" I remembered, ...
Read more
Gears and derailleur misalignment
Latest post 4 months ago
  My Trike.jpg (Size: 57.65 KB / Downloads: 50)   Wife Trike.jpg (Size: 60.74 KB / Downloads: 50) Although I have ridden bikes on and off since a kid (75 years old now), I have very little experience with anything other than a single speed bike. I recently purchased a new 7-speed Gospel adult tike, which needed assembly. My wife has the same model trike but older and p...
Read more
I'm curious—how often or after how many miles do people typically check or change their mechanical disc brake pads? I've been bikepacking for a while but never really followed a maintenance schedule. A few weeks ago, I took my bike to a mechanic because I heard some noise. The mechanic did a quick overhaul, and I was sent on my way. However, a few weeks later, while descending steep hills, I s...
Read more
Shifting is almost impossible
My wife's road bike has Shimano Sora shifters with a triple front derailleur (stock). The thumb switch on the front shifter is VERY hard to use and she can't do it when she's riding. I did a full adjustment of the front derailleur but it didn't change anything. One thing that I noticed is that the shifter works smoothly when the shifter cable is unattached from the derailleur, suggesting that the ...
Read more
7-speed bicycle with bent rim
Latest post 5 months ago
I recently bought a 7-speed bicycle practically brand new it still has a little rubber nipples on the tires apparently it got backed into in the garage and it bent the rear rim sideways my question is can I go out and buy another just like single speed 20 inch bicycle and put the 7-speed cassette onto that rim?...
Read more
Trek domane tyre
Hi I have a trek domane 2.3, and I have changed the rear tyre to 28 (it was 25 originally) The tyre rubs with the brake arm (v brake), I fear it doesn’t seem to be compatible Is there any way to adjust the position of the brake arm? I just need it to ne around 2mm higher Thanks...
Read more
Schwinn meridian rear drive axle
Latest post 6 months ago
Recently bought a slightly used 26" meridian trike. While replacing wider tires on the rear, I noticed an issue with the rear drive side wheel hub. The wheel is held on with a nut and single washer. The hub is not held firmly in a location on the axle and is able to slide back and forth on the axle a good half inch even though the nut is tightened all the way down to its bottom threads on the axle...
Read more
