How to Replace Your Pedals
Applies to both 1/2″ and 9/16″ thread sizes. The left pedal has a reverse thread.
Replacing a set of pedals on your bike may seem simple enough, but here’s a few tips that will help you prevent damage and make sure they stay on tight for those long rides. I recommend using a proper 15mm pedal wrench for this job, as they have a long handle and are designed to fit properly in the small axle slots.
When removing your pedals, the first step is to make sure you have both wheels firmly on the ground. This will give you better support for the leverage that is required to loosen your very tight pedal threads.
Right Pedal Removal
Loosen the right side pedal by turning counter-clockwise just like any traditional threaded nut. Notice how I have positioned the crank arm and pedal tool so that I can push down with more force.
Left Pedal Removal
It is very important to remember that the left pedal has a reverse thread, which keeps the pedal from unscrewing while you ride. To loosen the left side you will have to turn the wrench clockwise.
Pedal Installation
Before installing the new pedals, apply a thin coat of waterproof grease to the threads. This helps tighten your pedals and keep the treads from seizing, so that they can be removed in the future.
Tighten the right pedal by turning the wrench clockwise, and tighten the left pedal by turning counter-clockwise.
Related Links
- Jim Langley: Pedal Basics
- Park Tool: Pedal Installation and Removal
- Sheldon Brown: More Pedal Information
Recommended Tools
- Park Tool PW-3 Pedal Wrench
- Phil Wood Waterproof Grease
Categories
Latest post 3 days agoI live 5 km from the ocean (not sure if that's relevant), and I pretty much only mountain bike. After every ride, I hose down and clean my bike. I wipe them down with a cloth. After a few days, the ones not ridden have what looks like surface rust appear on the chain. Do you have any cost-effective remedies to solve this issue?...
Read moreRear v-brake repair
Latest post 1 week agoHi everyone, I'm new here and I've been trying to avoid taking my bike to a mechanic and save some money. I succesfully fixed my front but struggle with the rear, I got new brakes for the rear. I notice i think it might be the housing causing the noodle to be off centered and making the left brake pad to close to the rim. Any help would be greatly appreciated, thanks!! My next project is to attemp...
Latest post 1 month agoHello, Not sure if I should post this in buying advice or repairs, but here we are. I recently bought Schwinn cruiser an old one and I can't find the rear dropout bracket replacement. So I decided to try out a custom bike part manufacturer. Still waiting for my part, so if anyone has tried out a custom on demand manufacturer, please share your experience....
Latest post 1 month agoI have a Gazelle Esprit belt drive bike with hub gears which has a rear puncture. Can someone advise me on how to remove and refit the wheel? I'm aware that it can be quite complicated, but I have no option other than tackling it myself. The photos were taken with the bike upside down. IMG_20250122_105320.jpg (Size: 77.51 KB / Downloads: 51) IMG_20250122_105428.jpg (...
Read moreGrip Shifters
Latest post 3 months agoAll of my bikes are 7 or 8 speed and sometime in the past I bought a 9 speed chain for some unremembered reason. is there any reason not to use it on an 8 speed bike?...
Read moreTrek domane tyre
Latest post 6 months agoRecently bought a slightly used 26" meridian trike. While replacing wider tires on the rear, I noticed an issue with the rear drive side wheel hub. The wheel is held on with a nut and single washer. The hub is not held firmly in a location on the axle and is able to slide back and forth on the axle a good half inch even though the nut is tightened all the way down to its bottom threads on the axle...
Read more
