How to Replace a Wheel Rim
Learn how to replace a worn out wheel rim (rim transfer).
In this tutorial we will learn how to replace a worn out rim. This repair is often called a rim transfer.
What You’ll Need
For this job you will need an appropriately sized spoke wrench, a wheel truing stand, an optional nipple driver, waterproof grease and a toothpick, linseed oil, rim tape, and some tape or zip ties to fasten the rims together. You’ll also need a replacement rim. The new rim must be the exact same size and spoke count as your old rim.
Grease Spoke Holes
Using a dab of grease on a toothpick, grease all of the spoke holes on the new rim. You’ll only need a tiny bit. This helps the nipples turn easier when you’re tensioning the wheel.
De-tension Old Wheel
Next you’ll need to loosen all of the old spoke nipples. The safest way to do this is to start at the valve hole and loosen all of the spokes by turning clockwise 1/4 turn each. Repeat this step until all of the spokes in the wheel are de-tensioned but still attached.
Attach New Rim
Tape or zip-tie the new rim to the old rim in 2 places directly across from each other. Make sure that the valve hole and placement of the spoke holes in the rims match up exactly.
Transfer Spokes
One at a time, you’ll need to move each spoke from one side of the wheel over to the new rim. Turning counter-clockwise, unthread each nipple from the old rim and place a drop of linseed oil inside the nipple threads. This will keep the nipples tight while still allowing them to be turned in the future. Move the spoke over to the corresponding hole on the new rim. Thread the nipple on most of the way, but leave 2 spoke threads showing.
Once all of the spokes on the first side of the wheel are transferred, repeat the process and transfer the spokes on the other side of the wheel, until all of the spokes have been threaded onto the new rim.
True and Tension Spokes
You can now undo the tape or zip-ties and remove the old rim. Starting at the valve hole, tighten all of the nipples by turning each 1/4 turn counter-clockwise, all the way around the wheel. Repeat this until all of the spokes are fairly tight, and then tension and true the wheel. See the video titled how to true a wheel. In the next video we’ll learn how to properly tension your spokes.
Related Links
Recommended Tools
- Park Tool SW Spoke Wrenches
- Park Tool TS-2.2 Home Truing Stand
- Park Tool Nipple Driver
- Park Tool TM-1 Spoke Tension Meter
Categories
Latest post 3 days agoI live 5 km from the ocean (not sure if that's relevant), and I pretty much only mountain bike. After every ride, I hose down and clean my bike. I wipe them down with a cloth. After a few days, the ones not ridden have what looks like surface rust appear on the chain. Do you have any cost-effective remedies to solve this issue?...
Read moreRear v-brake repair
Latest post 1 week agoHi everyone, I'm new here and I've been trying to avoid taking my bike to a mechanic and save some money. I succesfully fixed my front but struggle with the rear, I got new brakes for the rear. I notice i think it might be the housing causing the noodle to be off centered and making the left brake pad to close to the rim. Any help would be greatly appreciated, thanks!! My next project is to attemp...
Latest post 4 weeks agoHello, Not sure if I should post this in buying advice or repairs, but here we are. I recently bought Schwinn cruiser an old one and I can't find the rear dropout bracket replacement. So I decided to try out a custom bike part manufacturer. Still waiting for my part, so if anyone has tried out a custom on demand manufacturer, please share your experience....
Latest post 1 month agoI have a Gazelle Esprit belt drive bike with hub gears which has a rear puncture. Can someone advise me on how to remove and refit the wheel? I'm aware that it can be quite complicated, but I have no option other than tackling it myself. The photos were taken with the bike upside down. IMG_20250122_105320.jpg (Size: 77.51 KB / Downloads: 50) IMG_20250122_105428.jpg (...
Read moreGrip Shifters
Latest post 3 months agoAll of my bikes are 7 or 8 speed and sometime in the past I bought a 9 speed chain for some unremembered reason. is there any reason not to use it on an 8 speed bike?...
Read moreTrek domane tyre
Latest post 6 months agoRecently bought a slightly used 26" meridian trike. While replacing wider tires on the rear, I noticed an issue with the rear drive side wheel hub. The wheel is held on with a nut and single washer. The hub is not held firmly in a location on the axle and is able to slide back and forth on the axle a good half inch even though the nut is tightened all the way down to its bottom threads on the axle...
Read more
