How to Replace Tektro Disc Brake Pads
Learn how to remove, install and adjust Tektro disc brake pads.
In this tutorial we’ll learn how to replace brake pads on Tektro Auriga Comp Disc Brakes. The pads should be replaced if they become contaminated with oil or dirt, or have less than 0.8 thickness remaining.
What You’ll Need
For this job you will need a 3 and 5mm allen wrench and a set of replacement Tektro disc brake pads.
Pad Removal
The first step is to remove the disc brake caliper by loosening and removing the two bolts holding the caliper to the adapter. Now unscrew and remove the retainer bolt, and then gently push out the pads and holder using your allen wrench. Once free of the caliper, the pads are easily removed from the pad connecting spring.
Pad Installation
Position each new pad on opposite sides of the holder so that both braking surfaces are facing each other. Taking care not to touch the braking surfaces, push the pads and connector spring together into the caliper so that the protruding lip with the retainer bolt hole is alligned with the bolt hole on the caliper. Reinstall the retainer bolt and tighten it to 3-5Nm with your 3mm allen wrench.
Pad Adjustment
To adjust the brake pads, loosely install the caliper so it’s snug but still loose enough to move. Then fully depress the brake lever. With the lever depressed, retighten the caliper bolts to 6-8Nm using a 5mm allen wrench.
Keep in mind that new disc brake pads require around 30-40 full stops to achieve their optimum breaking power. This process is called ‘bedding in’.
Related Links
Recommended Tools
- Park Tool TWS-2 Fold-Up Torx Compatible Wrench Set
- Tektro Hydraulic Bleed Kit
- Park Tool HXS-1.2 Hex Wrench Set
- Park Tool Wrench Combo Set
- Tektro Auriga Comp Hydraulic Disc Brake (Front)
- Tektro Auriga Comp Hydraulic Disc Brake (Rear)
Categories
Rear v-brake repair
Latest post 4 days agoHi everyone, I'm new here and I've been trying to avoid taking my bike to a mechanic and save some money. I succesfully fixed my front but struggle with the rear, I got new brakes for the rear. I notice i think it might be the housing causing the noodle to be off centered and making the left brake pad to close to the rim. Any help would be greatly appreciated, thanks!! My next project is to attemp...
Latest post 4 weeks agoHello, Not sure if I should post this in buying advice or repairs, but here we are. I recently bought Schwinn cruiser an old one and I can't find the rear dropout bracket replacement. So I decided to try out a custom bike part manufacturer. Still waiting for my part, so if anyone has tried out a custom on demand manufacturer, please share your experience....
Latest post 1 month agoI have a Gazelle Esprit belt drive bike with hub gears which has a rear puncture. Can someone advise me on how to remove and refit the wheel? I'm aware that it can be quite complicated, but I have no option other than tackling it myself. The photos were taken with the bike upside down. IMG_20250122_105320.jpg (Size: 77.51 KB / Downloads: 50) IMG_20250122_105428.jpg (...
Read moreGrip Shifters
Read moreTrek domane tyre
Read moreBianchi Oltre Pro Garmin Mount
Latest post 6 months agoI am wondering if anyone can help me with the garmin mount that came with my recently purchased Bianchi Oltre Pro. I was on a ride descending and the mount flew off, landing in the middle of the road with my garmin head unit. Luckily the head unit still works with a few minor scratches and cracks. From the picture you can see that it was not that the screws came loose, it was in fact the part of ...
Read more
