We have read all expert and user reviews on the RockyMounts AfterParty. In summary, this is what cyclists think.
- The RockyMounts AfterParty pivots 180 degrees to give full access to the vehicle’s rear.
- Buyers praise the sturdy build quality and anti-wobble hitch-tightening system.
- Bikes are secured at the wheels, meaning no frame or fork contact.
- The AfterParty’s tiered trays prevent bike interference.
- Testers and buyers say the rack is easy to install.
- The AfterParty tilts 30 degrees for easier trunk access. This works with bikes loaded.
- The rack folds when not in use and protrudes just 17.75” from the vehicle.
- RockyMounts provides detailed measurements of the rack in each of its positions.
- An above-average heavy-duty 10mm chain is provided for locking bikes to the rack.
- All keyholes have a cover to prevent dirt and rust from accumulating.
- The AfterParty isn’t compatible with 1.25” hitches.
- Certain cargo vans require an 8” hitch extension for door clearance.
- This rack doesn't work with fenders.
- Owners complain that the rack is heavy and difficult to maneuver.
- The AfterParty is expensive, especially for a two-bike rack.
- Heat from exhaust pipes pointed at the rack risks damage. RockyMounts warns of this and says that exhaust pipes should face down or away.
- The AfterParty may block backup sensors on some vehicles.
The RockyMounts AfterParty is a zero frame contact, swing-away hitch rack for 2" receivers. It supports two 60lb bikes, tires up to 3" wide, 20" to 29" wheels, and 36" to 55" wheelbases. It's not compatible with fenders. Testers and owners praise the easy trunk access, clever tiered trays, sturdiness, and handy features. Users complain that the high weight makes it difficult for one person to maneuver. While the AfterParty is considered a great rack for those needing the swing-away feature, it's expensive, limited to two bikes, and incompatible with heavy e-bikes and fat tires.BikeRide finds and shows you the best prices of the bikes you want to buy. Prices constantly change and it’s impossible to compare them all yourself.
94/100 based on 2 rated expert reviewsRockyMounts AfterParty Bike Rack Review
RockyMounts AfterParty Review
Is the RockyMounts AfterParty the Best Bike Rack on the Market?
Best Bike Vehicle Racks
Bike Rack Comparison
2 hours ago
15 hours ago
