RockyMounts GigaWatt
80/100
Categories
Maximum Load Capacity
Maximum Weight Per Bike
80 lb
Vehicle Type
64 lb
Material
Steel, Aluminum
We have read all expert and user reviews on the RockyMounts GigaWatt. In summary, this is what cyclists think.
  • The RockyMounts GigaWatt supports two 80lb e-bikes.
  • The GigaWatt comes with a ramp for loading and unloading bikes.
  • A tester says bikes remain stable when mounted, thanks in part to the anti-wobble hitch pin
  • The tilt mechanism allows access to the vehicle’s rear with bikes loaded.
  • Bikes are secured at the wheels, meaning no frame contact.
  • The GigaWatt folds toward the vehicle when not in use, reducing the rearward footprint to 20”.
  • RockyMounts provides a chain lock with this rack, unlike the more commonly included wire locks.
  • This rack is compatible with RVs and fifth-wheel trailers if certain conditions are met.
  • The GigaWatt is compatible with bikes that have fenders.
4 reasons not to buy
  • The GigaWatt isn’t compatible with 1.25” hitch receivers.
  • A tester finds the trays difficult to install with the included tools.
  • One reviewer describes the tilt mechanism as stiff and difficult to operate.
  • This rack is heavy at 64lb.
The RockyMounts GigaWatt is a platform hitch rack for 2” hitch receivers. It supports two 80lb e-bikes and is compatible with 20” to 29” wheels, 34” to 55” wheelbases, and tires up to 4.5”. Weight capacity per bike decreases when used on RVs and fifth-wheel trailers. RockyMounts provides a loading ramp and an above-average chain lock with this rack. In the sole expert review, the tester says the GigaWatt feels solid and that bikes are stable when loaded. The rack tilts, but the mechanism is challenging to operate. Overall, the versatile GigaWatt seems a good option for transporting e-bikes.
84/100 based on 1 rated expert review
Great Lakes Bike Ski Boat
Rockymounts Gigawatt E-bike Rack – The Easiest Rack to Load Heavy E-bikes
Overall, the bike rack is really solid, [and] it holds the bikes very securely.
Bike Rack Comparison
RockyMounts GigaWatt in comparison to averages
