RockyMounts MonoRail
92/100
We have read all expert and user reviews on the RockyMounts MonoRail. In summary, this is what cyclists think.
  • The RockyMounts MonoRail comes in three versions: Solo, 1.25", and 2".
  • The MonoRail Solo and 2” are compatible with an add-on that increases capacity by one bike. This reduces weight capacity from 60lb to 45lb per bike.
  • Buyers appreciate the MonoRail’s versatile compatibility, fitting 20” to 29” wheels, tires up to 5” wide, and wheelbases between 36” and 50”.
  • The trays can be adjusted horizontally to offset bikes and prevent or reduce bike-on-bike contact.
  • Owners praise the rack’s sturdiness, highlighting how secure bikes stay while driving.
  • The rear-wheel cradles adjust to accommodate different wheelbase lengths.
  • Experts and owners say installation is quick and easy.
  • RockyMounts provides fat-tire extension straps for free, unlike some competing brands.
  • The tilting feature allows access to most trunks while bikes are mounted.
  • The Rocky Mountain Solo comes with an adaptor sleeve for swapping between 1.25” and 2” receivers.
  • Many buyers complain that the included plastic locks are easy to break off. Sturdier metal locks must be purchased separately from RockyMounts.
  • Some owners note wobbling as the hitch pin bolt loosens with use.
  • Several owners find the rack difficult to maneuver onto the hitch.
  • Cargo van owners may need to purchase RockyMount’s 8-inch Hitch Extension so handlebars can clear the door (MonoRail 2” and Solo).
  • RockyMounts lists several vehicle models that require the 8-inch Hitch Extension added to the MonoRail 1.25” to prevent the exhaust from burning it when folded.
  • Some truck owners find the rack doesn’t tilt far enough to allow the tailgate to open when bikes are mounted.
  • The MonoRail Solo and 1.25” are not compatible with Class 1 hitch receivers.
The RockyMounts MonoRail is a platform hitch rack for bikes. The MonoRail 1.25-inch and 2-inch hitch receiver versions fit two bikes; the Solo carries one. Testers and owners appreciate the versatile compatibility, adjustability, and how stable the bikes are while in transit. Complaints include low-security plastic locks and wobbling due to hitch pins loosening over time. Overall, the MonoRail is considered a good, relatively inexpensive option in the category. However, potential buyers should double-check hitch receiver and vehicle compatibility before purchase.
Categories
Maximum Load Capacity
Maximum Weight Per Bike
60 lb
Vehicle Type
25, 40.4, 44 lb
Material
Aluminum, Steel
RockyMounts MonoRail Review
If you don’t want to spend a small fortune on a well-designed, user-friendly, versatile, and secure bike rack, we think this [is] an excellent option to consider.
Cyclingnews
RockyMounts MonoRail Solo Hitch Bike Rack Review
This is a bare-bones rack that is relatively inexpensive and exceptionally easy to move and store. It’s also priced at a level that makes sense for what you get.
Mountain Bike Action
Product Review: RockyMounts MonoRail 2-Bike Rack
The MonoRail is a smooth-operating hitch rack that is tough enough for your mountain shuttle journeys.
Singletracks
The RockyMounts MonoRail Hitch Rack for Bikes Is Rocky Solid [Review]
… this thing is super simple. [It] keeps your bike stable and in place and it doesn’t touch your frame.
Red Mountain Rider | FAT BIKE skinny legs
RockyMounts MonoRail 2.0 Bike Rack Review
… this thing will fit everything from a road bike to a fat bike with no modifications…
Cobra Kyle
RockyMounts MonoRail Hitch Rack Review
I would say buy this rack if you are in need of a solid, simple, and reliable way to transport your bike that won’t scratch your bike frame.
Reviews, Tutorials & Tech
Review and Install of RockyMounts MonoRail 2” 2-Bike Hitch-Mount Platform Bike Rack
… I have to say, this is [an] extremely easy installation…
Honestly, I would say that this is a win so far.
BIKE Magazine
Beatdown: RockyMounts MonoRail 2-Bike
There’s nothing exotic about the RockyMounts MonoRail, and that’s exactly what’s so exotic about it. It’s easy to buy, easy to use, and easy to keep.
Gear Junkie
One-Bike Rack: Rocky Mounts MonoRail Solo Reviewed
Overall, I think Rocky Mounts did a great job with its flexible bike hauler.
Dirt Rag Mag
Review: RockyMounts MonoRail Platform Hitch Rack and Single Bike Add-on
This is one of the cheapest and lightest platform hitch racks on the market from a reputable brand that also allows an add-on.
Active Gear Review
RockyMounts MonoRail Hitch Bike Rack Review
The RockyMounts MonoRail hitch bike rack is the perfect bike rack to get your bike to the next trail or destination safely.
94/100 based on 469 ratings
    82%
    13%
    3%
    1%
    2%
Bike Rack Comparison
RockyMounts MonoRail in comparison to averages
