We earn affiliate commission.
Learn more
20.61 lb
We have read all expert and user reviews on the Rondo MYLC CF. In summary, this is what cyclists think.
16 reasons to buy
- All reviewers highlight the MYLC CF's stability, saying it handles fast and technical gravel trails with confidence.
- Experts agree the MYLC CF excels on steep downhill sections with stable and reassuring performance.
- One expert relishes the bike's potential at the extreme end of gravel endeavors.
- The frame has routing for a dropper seatpost and is compatible with 1x and 2x drivetrains.
- The MYLC CF has clearance for 650b x 54mm or 700c x 47mm tires.
- The MYLC CF has mounts for three bottle cages, a top tube bento box, and fenders, and the fork has triple mounts and internal routing for dynamo wiring.
- Rondo's TWIN TIP dropout design provides a choice of two geometries (high and low).
- The low geo setting works to "epic" effect in the rough, and the high position is sportier and more aero.
- One expert says the wonderfully balanced MYLC CF1 achieves its off-road ambitions with aplomb.
- Testers praise the smooth ride, highlighting the effectiveness of the excellent foam-filled Vibrocore handlebars (CF1).
- The 46cm handlebar width and 25-degree flare provide extra leverage off-road.
- Vittoria's Terreno Mix 700c x 40mm tires complement the bike's abilities and perform well, even in sloppy or muddy conditions.
- At 20.6lb, the CF1 build is light for a mid-level gravel bike.
- SRAM's Rival AXS groupset (CF1) delivers superb shifting and progressive braking that's easy to modulate, according to testers.
- Reviewers say the MYLC CF rolls relatively well on asphalt.
- A tester likes Rondo's eye-catching approach to frame design. Another compliments the very high standard of finish.
- Experts rue the omission of a dropper seatpost, saying a bike with these gravity-riding chops should come with one.
- The MYLC CF's geometry puts the rider a bit too far forward during out-of-the-saddle efforts when climbing, impacting rear-wheel traction.
- One expert says sizing runs large and recommends choosing a smaller size than Rondo suggests.
- A tester laments the choice of a press-fit bottom bracket over a more durable, easier-to-maintain threaded one.
- Two experts say maneuverability is compromised by the emphasis on stability.
- A reviewer thinks the TWIN TIP dropout feature is unnecessary and recommends leaving it set to low.
The Rondo MYLC CF is a gravity-focused graveller that experts say blurs the lines between gravel and mountain bikes. The carbon MYLC comes in two builds: CF1 and CF2. Reviewers praise the stable, confidence-inspiring handling, which shines at the extreme end of gravel riding. Experts deem the MYLC CF suitable for experienced riders and beginners or "ex-roaders." Despite having ample tire clearance and mounts and being compatible with 650b or 700c wheels and 1x or 2x drivetrains, the frame remains relatively lightweight. Complaints seem relatively minor given the overwhelming praise the MYLC CF receives, but all experts recommend adding a dropper seatpost.Expert Reviews
84/100 based on 3 rated expert reviewsRondo MYLC CF1 Review
Rondo MYLC: The Gravel Joy Machine [French]
Rondo MYLC – Trailblazer With Drop Bars [Polish]
Will All Gravel Bikes Be Like This in the Future? Rondo MYLC CF1 Test (Eng Sub) [Polish]
Gravel and adventure bikes with the highest BikeRide Scores
Rondo MYLC CF in comparison to averages
9 hours ago
10 hours ago
17 hours ago
