We have read all expert and user reviews on the Salsa Moraine. In summary, this is what cyclists think.
11 reasons to buy
- This bike comes in two Shimano-equipped builds: Deore 12-speed and CUES 10-speed.
- According to a reviewer, the geometry, beefy tires, and long travel (160mm front, 145mm rear) help make “hard-charging” descents feel easy.
- An expert appreciates the stability afforded by the long wheelbase, though this comes at the expense of playfulness, they add.
- The range in PAS 1 impresses a tester who covers 35 miles and has two bars remaining.
- A reviewer says the Moraine hardly looks like an e-bike.
- One expert finds the top tube control panel intuitive to use and read.
- The Split Pivot+ suspension platform supports an unusual range of travel choices, allowing owners to run 140mm to 160mm forks and 125mm to 145mm shocks.
- An expert says the Fazua drive system works flawlessly, highlighting the smooth power engagement.
- The three power settings are customizable via Fazua’s app.
- The Moraine uses SRAM’s UDH.
- The frame can run 27.5” wheels with the flip-chip in its high setting.
- The size-small frame is rated for 5’2” to 5’7”, but a 5’5” tester is at the limit of the standover height.
- An expert points out that the Moraine is heavy for an electric trail bike at this price point.
- The Moraine is expensive for an aluminum-framed e-MTB.
- Each build only comes in one color.
- An expert reports pedal bob while climbing.
Salsa’s Moraine is an electric trail mountain bike with an aluminum frame and Fazua mid-drive system. It comes in two builds with different groupsets and suspension components. There is only one expert review. In it, the tester praises the Moraine’s composure on challenging descents, the smooth pedal assist, the stealthy design, and the ample range. Complaints include the size-small frame’s long reach and high standover height, pedal bob when climbing, and the lack of color choices and size-specific components. Further reviews may alter the overall picture, but the Moraine seems a solid trail e-MTB, though it's pricey and not for short riders.Expert Reviews
88/100 based on 1 rated expert reviewSalsa Moraine Electric Mountain Bike Review
Best Mountain Bikes
4 hours ago
