Salsa Wanderlust
78/100
We have read all expert and user reviews on the Salsa Wanderlust. In summary, this is what cyclists think.
6 reasons to buy
  • An expert and multiple owners deem the Wanderlust sturdy and robust.
  • Owners say the “rigid” Wanderlust remains stable in use.
  • After 2,000 miles of riding over different terrains, an owner calls the Wanderlust awesome.
  • An optional seatpost clamp can be purchased to install the rack on frames without seatstay eyelets.
  • Salsa offers rack struts with a 45-degree angle for frames that don’t fit the included straight struts.
  • A taillight mounting bracket is included with the Wanderlust HD.
  • Testers and owners complain that installation is tricky and requires some skill.
  • Multiple owners say tightening the struts is awkward as the bolts are positioned close to the frame.
  • Salsa says this rack may not fit touring frames with level top tubes.
  • The HD version won’t fit on most bikes with 29” wheels.
  • Installation requires a hacksaw to cut the struts to size.
Salsa’s Wanderlust is a rear cargo rack available in two versions: aluminum (33lb capacity) and Chromoly steel HD (55lb capacity). The Wanderlust is best suited to Salsa bikes without Alternator dropouts, though adapters can be purchased to expand compatibility. Otherwise, compatibility is limited. Reviewers praise the rack’s sturdiness and stability when mounted. Complaints highlight the tricky installation and need for a hacksaw. Overall, owners deem the Wanderlust a good, durable option, but interested buyers should verify compatibility before purchase.
Categories
Rack Type
Weight Capacity
33, 55 lb
Fits Wheel Sizes
Disc Brake-Compatible
2.30, 2.38 lb
Material
Aluminum, Chromoly Steel
82/100 based on 1 rated expert review
Bi-Polar Backpacker
Salsa Wanderlust Rear Rack Review
[It’s] quite [expensive] for a rack, but if it fits your Salsa bike it will fit your Salsa bike amazingly, and it will look great and function perfectly…
Man with the dogs
Salsa Wanderlust Rear Rack on a Salsa Cutthroat
So far I like it. [It] seems pretty strong, [but] I might want to eventually cut these struts off…
86/100 based on 30 ratings
    63%
    23%
    7%
    7%
Bike Rack Comparison
Salsa Wanderlust in comparison to averages
