If you find a lower price, email us at contact@bikeride.com with documentation of the price. We’re committed to making sure that the cost of a bike does not keep you from cycling!
We have read all expert and user reviews on the Santa Cruz Megatower. In summary, this is what cyclists think.
26 reasons to buy
- The Megatower is coil shock compatible. A coil shock gives riders a more playful and poppy ride.
- The VPP suspension setup provides excellent mid-stroke support to riders.
- Big hits are handled easily, with the supportive and supple VPP suspension setup.
- The Megatower has a low center of gravity that gives riders excellent control through corners and turns.
- The bike has clearance for 2.6” tires.
- Geometry adjustments in the chainstay and shock allow riders the ability to adjust the Megatower to meet the needs of the terrain they traverse and their riding style.
- The Megatower is available in numerous build options with two different carbon frames. The CC version of the frame is lighter, stronger and more expensive.
- The frame and bearings on the bike have a lifetime warranty. Builds with Santa Cruz’s Reserve wheels also get a lifetime warranty on their wheels.
- The firm setup of the Megatower requires riders to have an active and engaged riding style on the bike.
- Experts were surprised to find the bike was comfortable for long climbs in the saddle.
- Testers rarely found a need to use the shock’s lockout on climbs.
- The Megatower can utilize a fork up to 180mm and a triple crown fork. This allows riders to better utilize the bike as a downhill bike.
- The bike has a short seat tube, allowing riders to run a longer dropper post.
- Internal cabling is clean and quiet on the Santa Cruz Megatower.
- The centered riding position and slack headtube angle allow riders to easily maneuver the bike through chunky terrain.
- A ribbed chainstay protector dampens the sound from chain slap on the Megatower.
- The downtube of the bike has a protector, keeping it from becoming damaged by rocks on the trail.
- Santa Cruz produces this mountain bike in sizes small through XXL, allowing a wide range of riders to experience this bike.
- The shock fender protects the shock from being damaged on rides.
- Santa Cruz specs the Megatower with Maxxis Assagai tires with a durable EXO casing. These are ideal for exploring rough and rowdy terrain.
- Experts found the bike responded well on flat and flowy terrain when they pumped through rollers and actively guided the Megatower.
- With 29” wheels, riders will find the Santa Cruz Megatower can easily maintain speeds through obstacles.
- The bike’s lower-link VPP suspension placement allows room for a water bottle.
- Testers were pleased to find that, even with a longer wheelbase, the Megatower felt nimble and stable on tight and twisting trails.
- Large 200mm rotors paired with powerful Shimano or SRAM brakes provide excellent stopping power to riders of the Megatower.
- A steep seat tube angle helps riders maintain traction on steep terrain.
3 reasons not to buy
- Most experts agree the Megatower is expensive.
- The bike is not available with an aluminum frame.
- Experts found the bike required them to ride actively.
The Megatower is a capable enduro bike that comes alive on the descents. The bike has great mid-stroke support for climbing, with its lower link VPP suspension. The steep seat tube angle and Maxxis Assagai tires help riders maintain traction, even on steep technical climbs. This 29er requires riders to ride actively, but when they do they will be pleased to find how lively the bike can be. The Megatower is coil shock compatible. The bike is expensive but comes with a lifetime warranty on the frame and bearings.Expert Reviews
70/100 based on 2 rated expert reviewsWhat Does Vital Think? The New Santa Cruz MEGAtower
Santa Cruz Megatower C R review
Tested: Santa Cruz Megatower
Bike Test Santa Cruz Megatower
[Tested] Santa Cruz Megatower
New Santa Cruz Megatower – Ridden & Rated
2019 Santa Cruz Megatower CC XO1 // Bike Review
Should You Buy The Santa Cruz Megatower In 2020? | Mountain Bike Review
Santa Cruz Megatower First Ride Review – The Big Wheel Nomad We’ve Been Waiting For.
Long Term Santa Cruz Megatower Review
Santa Cruz Megatower Test Ride & Review
Should You Buy The Santa Cruz Megatower? (Megatower Demo and Visiting Arts Cyclery)
2 Things You Didn’t Know About The 2020 Santa Cruz Megatower // Review
Santa Cruz Megatower 2021 Bike Review
Megatower Santa Cruz – Long Term Review
Santa Cruz Megatower Review | California Edition | Guest Rider
2019 Santa Cruz Megatower Demo Ride & Review MTB
Santa Cruz Megatower Review in Morzine.
Santa Cruz Megatower Review & Initial Thoughts
2019 Santa Cruz Megatower | Test Ride and Review | How Does It Compare to My La Sal Peak?
Santa Cruz MegaTower – The Bike I Should Have Bought?
Santa Cruz Megatower Ride & Review Dupont 2019
Santa Cruz Megatower: First Ride Review
Introducing the Santa Cruz Megatower 29 – Ridden in NZ
Santa Cruz Megatower CC X01 Reserve On Test – The Most Versatile Bike In Santa Cruz’s Portfolio
Review: 2019 Santa Cruz Megatower – Stiff & Solid, But Not That Sensitive
The Santa Cruz Megatower Is Here And The Rodfather Has Ridden It
‘2020’ Santa Cruz Megatower
Best Mountain Bikes
14 hours ago
2 days ago
2 days ago
