We have read all expert and user reviews on the Saris Cycle Glide. In summary, this is what cyclists think.
5 reasons to buy
- The lone expert tester of the Cycle Glide praises the build quality, and multiple owners say it's holding up well after a year.
- Owners say the gliding track system makes it easy to retrieve a specific bike when the rack is full.
- Small wheel kids’ bikes fit on Cycle Glide.
- Owners appreciate how the Cycle Glide helps declutter storage spaces.
- Saris provides a lifetime warranty with this storage rack.
4 reasons not to buy
- Several owners report bikes falling when the gliding rail detaches from the ceiling track due to the pin and e-ring mechanism failing.
- Installation is time-consuming and cumbersome and requires numerous tools.
- The Cycle Glide can only be installed on ceilings with joists, and a stud finder may be needed to locate them.
- Loading and unloading bikes requires lifting and turning them upside down, which may be too physically challenging for some.
The Saris Cycle Glide is a ceiling-mounted bike storage system that holds bikes by the wheels on adjustable tracks. The base rack supports up to four 50lb bikes, and is expandable to fit six. The Cycle Glide can be adjusted to fit small kids' bikes, wheelbases up to 56", and 2.5" tires. Owners and the tester praise the practical design, but installation proves time-consuming for some, and loading and removing heavier bikes is physically demanding. Some owners also say the rack fails, causing bikes to drop. Nonetheless, most owners consider the "cleverly designed" Saris Cycle Glide a practical storage solution and a worthwhile investment.BikeRide finds and shows you the best prices of the bikes you want to buy. Prices constantly change and it’s impossible to compare them all yourself.
90/100 based on 1 rated expert reviewSaris Cycle Glide Review
Best Bike Garage And Storage Racks
Bike Rack Comparison
1 hour ago
15 hours ago
