Saris Door County
73/100
We have read all expert and user reviews on the Saris Door County. In summary, this is what cyclists think.
  • With its electronic lift, the Door County minimizes manual handling of heavy e-bikes and bikes, making it well-suited to injured, older, smaller, and disabled users.
  • The Door County features its own stop lights, turn signals, and running lights.
  • Users can load 2x e-bikes on the Door County, weighing up to 60 lb each.
  • The Door County accommodates tires up to 3” wide and wheelbases up to 48” long.
  • Testers praise the Door County’s sturdy build and on-road stability.
  • This rack tilts to allow access to your vehicle’s rear door, even with bikes loaded.
  • Integrated locks secure bikes to the Door County rack - and the rack to your car.
  • The Door County is fully compatible with bikes that have fenders mounted.
  • For ease of storage, the Door County folds up, then rolls away on its own wheels.
  • The Door County arrives almost completely assembled.
  • For taller vehicles, the Saris Door County may not lower to ground level.
  • An expert was disappointed that the Door County doesn’t fit tires over 3” wide.
  • The Door County ain’t cheap, with its electronic bells and whistles.
  • Saris state clearly that the Door County is not compatible for use with RVs.
  • An expert found it difficult to attach Saris’ ‘lobster claw’ to a small-framed e-bike.
The Saris Door County is designed for owners of heavy e-bikes and bikes. A motorized lift takes the load off of owners with injuries, decreased strength, a disability, or back and shoulder problems. It’s powered via a standard 7-pin trailer connector, along with this rack’s own signal and stop lights. On vehicles of average height, this rack will lower to ground level to eliminate the need to lift your bike. While not designed to fit tires over 3”, one tester did successfully fit 4” tires. The Door County requires a 2” hitch.
Categories
Maximum Load Capacity
Maximum Weight Per Bike
60 lb
Vehicle Type
63 lb
Material
Steel, Aluminum, Plastic
74/100 based on 1 rated expert review
74
Jeremiah Mcintosh
Saris Door County Hitch Mounted Bike Rack Review
~ Best Car E-Bike Rack for You?
If you’re an older person and have a harder time lifting e-bikes up, this might be a good option for you. Some of you might like this style of clamping system but I feel like it’s a little bit finicky. The rack itself is pretty sturdy.
evolutionaryTom
This Rack Solves Two BIG Issues When Hauling E-Bikes
This rack solves a lot of problems for e-bikers, especially how to get out and about with your heavy bikes. It’s very stable. It’s built like a tank. I felt really secure driving with it. The lights are genius. My tires fit in the channel, both the 3” and the 4”.
SmokinSteve
Saris Powered E-Bike Rack Review
It’s a thing of beauty. It’s going to save your back. Whether you’re old and have a bad back or you’re young and you want to keep from getting a bad back, this is the ticket and those e-bikes are heavy and they’re hard to lift up.
Saris Door County Electric Assist E-Bike Rack: First Look
A rack purpose-built for carrying heavy electric bikes. It does the lifting for you. It’s a back-saving, bike-carrying and, quite honestly, very cool piece of e-bike tech.
Wirecutter
The Best Bike Racks and Carriers for Cars and Trucks
If you want to transport an e-bike and have limited strength or dexterity: consider the Saris Door County. It’s not hard to carry or lift into the hitch.
91/100 based on 14 ratings
    79%
    7%
    7%
    7%
Compared to other bike racks
#36 Best Vehicle Rack
Bottom 10%
#32 Best Hitch Rack
Bottom 20%
#10 Best Saris Rack
Bottom 30%
#70 Best of All Racks
Bottom 10%
Bike Rack Comparison
Saris Door County in comparison to averages
