Saris Freedom
78/100
We have read all expert and user reviews on the Saris Freedom. In summary, this is what cyclists think.
5 reasons to buy
  • The Saris Freedom secures the bikes at three points. Experts and buyers praise the stability of the bikes during transport.
  • Owners appreciate the wide range of bikes the rack can carry, including varied frame shapes, e-bikes, and those with fenders.
  • Once assembled, most find the Freedom is easy to install, say owners and testers.
  • A plastic adapter (included) adds compatibility with 2” hitch receivers.
  • The rubber coating on the frame straps prevents the harder plastic from damaging frame paint.
10 reasons not to buy
  • Several owners report missing nuts and bolts upon arrival, delaying assembly and installation.
  • Some buyers complain of cracked wheel trays and broken straps.
  • The two outer trays of the Freedom 4 have a reduced weight capacity of 35lb per bike.
  • Bottle cages obstruct the frame straps, so users must feed them through the cage to tighten.
  • Several owners report the tilt lever breaking upon first use.
  • Some report the bolt that secures the down tube cradle loosening over time.
  • E-bikes with down tube-integrated batteries require Saris’s Long Straps.
  • Experts say that preventing bike-on-bike contact requires a lot of shuffling, especially with the third and fourth bikes on the Freedom 4.
  • The Freedom isn’t compatible with RVs.
  • The hitch doesn’t lock to the vehicles.
The Saris Freedom platform hitch rack comes in two-bike and four-bike versions. Larger wheel holders and longer straps for fat tires are available separately. Reviewers praise the rack’s sturdiness and compatibility with varied frame shapes. Complaints include missing nuts and bolts from the assembly kit, low-quality plastic components, and difficulty loading multiple bikes. Potential buyers should consider weight capacities and hitch compatibility. Most consider the competitively priced Saris Freedom a solid platform rack, but some of the materials are lower quality, which may shorten its lifespan.
Categories
Maximum Load Capacity
Maximum Weight Per Bike
35, 60 lb
Vehicle Type
20, 53 lb
Material
Steel, Rubber
72/100 based on 2 rated expert reviews
70
Cycling Weekly
Saris Freedom 2-Bike Bike Rack Review – Simple, Effective and Made in the USA
The ratchet straps are fiddly and it doesn’t feel as sturdy as other designs – but the price is competitive and it’s straightforward to use.
Saris Freedom 4 Hitch Bike Rack Review
Overall, if you have a more traditional-shaped bike frame, I think this could be a really good bike rack for you.
David's Review Roundup
Hit the Road With Confidence: Saris Freedom Bike Hitch Car Rack Review | 4-Bicycle Carrier
Overall, this is a great four-bike hitch rack.
77/100 based on 258 ratings
    53%
    16%
    9%
    7%
    15%
Compared to other bike racks
#34 Best Vehicle Rack
Bottom 20%
#30 Best Hitch Rack
Bottom 20%
#9 Best Saris Rack
Bottom 40%
#67 Best of All Racks
Bottom 20%
Bike Rack Comparison
Saris Freedom in comparison to averages
