Saris SuperClamp
92/100
If you find a lower price, email us at contact@bikeride.com with documentation of the price. We’re committed to making sure that the cost of a bike does not keep you from cycling!
We have read all expert and user reviews on the Saris SuperClamp. In summary, this is what cyclists think.
  • Saris’s SuperClamp comes in two versions: EX (two or four-bike) and the RV-compatible HD (two-bike).
  • This rack supports 4" tires, 20" to 29" wheels, and 50" wheelbases. An adapter can be purchased for tires wider than 4".
  • Reviewers find the SuperClamp easy to install.
  • Experts and owners say the rack holds bikes securely while driving.
  • Bikes are clamped at the wheels, meaning zero frame contact.
  • The two-bike SuperClamp versions are lightweight for the platform hitch category.
  • Loading and unloading bikes is easy, according to reviewers and buyers.
  • The tilt feature allows access to most trunks.
  • Integrated cable locks add basic security but shouldn’t be relied on fully.
  • The rack folds up to reduce rearward protrusion when installed and not in use.
  • The SuperClamp EX four-bike is more compact than most platform racks, protruding just 50” from the vehicle’s rear when open.
  • Long-term users find the SuperClamp durable.
  • Installing or removing the hitch pin requires a 3/4-inch (19mm) wrench.
  • Buyers report a slight wobble at the hinge. Saris claims this design isn’t a risk to the rack.
  • One tester complains that two 20” kids’ bikes with different wheelbases don’t fit on the same tray.
  • Bikes sit close together and may touch when the rack is fully loaded.
  • Backup sensors on some vehicles may be blocked by the rack.
  • The outer tray of the SuperClamp EX four-bike only supports 35lb per bike.
The Saris SuperClamp is a platform hitch rack available in two versions: EX (two or four bikes) and HD (two bikes). The EX two-bike is compatible with 1.25” and 2” hitches; the HD is suitable for RVs but not when used with the fat tire adapters. Reviewers praise the ease of use, durability, low weight, and compact design. However, the compactness means loaded bikes sit close together. Other complaints are minor. Overall, experts and owners consider the Saris SuperClamp good value.
Maximum Load Capacity
Maximum Weight Per Bike
35, 60 lb
Vehicle Type
35, 38, 63 lb
Material
Steel, Plastic
89/100 based on 2 rated expert reviews
Saris SuperClamp EX 2 Bike Rack Review – A Heavy-Duty but Lightweight Option?
Overall… it’s a really good hitch rack. With a… couple of tweaks to make it a little bit more robust, I think it would be a real winner…
Two Wheeling Tots
Saris SuperClamp EX 4 Review
If you’re looking for a rack that can carry 24” kids’ bikes, is easy to load and unload, and has a low profile… the Saris SuperClamp EX 4 is an excellent choice.
Saris SuperClamp EX 4-Bike Rack
[It’s] not cheap, but it’s cheaper than the 1UP and it’s definitely more compact.
Part Time Outdoors
Saris SuperClamp EX 2-Bike Hitch Rack Review
I’m pretty happy with it so far. I don’t really see any downfalls with it.
KevCentral
Best Bike Rack After 6 Years of Use – Issues? Would I Buy the Saris SuperClamp Again?
I have been happy with this… [I] can’t believe I’ve been using this for six years.
Chris Burdick
Saris SuperClamp EX Unbox and Review
If you compare it to [Küat and Thule]… it’s a heck of a lot less.
Cars-R-Coffins
Saris SuperClamp EX 2 Is a Champ
The SuperClamp was a champ the entire way. No noise, no swaying motion, no bouncing bikes, totally stable.
87/100 based on 266 ratings
    67%
    17%
    5%
    5%
    6%
Bike Rack Comparison
Saris SuperClamp in comparison to averages
