If you find a lower price, email us at contact@bikeride.com with documentation of the price. We’re committed to making sure that the cost of a bike does not keep you from cycling!
We have read all expert and user reviews on the SCOTT Ransom. In summary, this is what cyclists think.
- SCOTT's Ransom comes in three tiers: carbon 900 RC and carbon mainframe/aluminum swingarm 910 and 920.
- Experts say the Ransom climbs well for an enduro thanks to the steep seat angle, low center of gravity, traction, and minimal pedal bob.
- The six-bar suspension platform and FLOAT X Nude shock combine to provide excellent small bump sensitivity and absorption of big hits.
- The TracLoc remote allows riders to quickly change rear shock characteristics (Descend, Traction Control, and Lockout).
- Experts relish the Ransom's stability and composure on descents.
- The Ransom’s balanced geometry and traction inspire confidence, allowing experts to carry more speed through corners.
- Reviewers find the stiff frame improves agility, control, and the ability to carry speed while descending.
- Testers praise the traction and casing protection from the tires.
- An expert appreciates how the low standover and long dropper travel provide freedom of movement while riding.
- The Ransom can take a 180mm suspension fork, and the chainstay flip-chip allows the use of a 27.5" rear wheel.
- The head angle can be set in three positions by reversing the stock headset cup or swapping to the included 'neutral' one.
- Finishing touches like the sag meter, easy-to-use rear shock access door, internal frame storage, and included tool kit impress testers.
9 reasons not to buy
- Installing the neutral headset cup requires disconnecting all cabling and bleeding the brakes.
- Only the colorway and saddle differ on the Contessa Ransom 910 women's build.
- The one-piece cockpit (Ransom 900RC and 910) complicates swaps, adjustments, and servicing.
- Testers say the headset-integrated cabling and enclosed shock add complexity to servicing.
- Two testers say the stiff cockpit (900 RC, 910) causes arm fatigue on long rides.
- The rear wheel on a Ransom 910 test bike requires re-tensioning of all spokes after just a few bike park laps.
- Dirt buildup may make it difficult to close the frame storage door's latch.
- Adjusting the rear shock using the TracLoc creates a suspension imbalance with a more "forward-pitched bias," according to an expert.
- Two reviewers complain that the 210mm dropper doesn't insert fully into the size L frame.
The SCOTT Ransom is an enduro MTB available in four builds and three tiers: 900 RC, 910, and 920. The Ransom is most praised for its ability to handle the gnarliest descents with composure yet climb efficiently and comfortably. Testers relish the Ransom's stability, traction, and ability to take corners at speed thanks to the supportive suspension platform and balanced geometry. The most frequent complaints focus on the heavy integration of the cockpit, shock, and cabling, which adds complexity to maintenance and adjustments. Overall, experts say the versatile and capable Ransom "rips."Expert Reviews
87/100 based on 3 rated expert reviewsThe SCOTT Ransom 900 RC Hides Its Shock Inside the Frame, but Boasts a Ride That Makes Mincemeat of Climbs and Descents
2024 SCOTT Ransom Review | An Enduro Bike From the Future
SCOTT Ransom 900 RC Review: Go Big on a DH-Ready Enduro Bike I Can Pedal Uphill, Too!
SCOTT Ransom Bike Review
Release and First Ride The New SCOTT Ransom
SCOTT Ransom 900 RC – In Our Big 2024 Enduro Comparison Test
Review: The New 2024 SCOTT Ransom 900 RC Has All the Integration
We Test the SCOTT Ransom 2024: Much More Than a Hidden Shock
SCOTT Ransom 900 RC Test: Gravity Becomes Light! [Italian]
[Test] New SCOTT Ransom: Purebred Enduro [Italian Video]
New Ransom SCOTT’s First Gravity Bike Has a 6-Pivot Pattern [Italian]
Test – New SCOTT Ransom 900 RC: From Enduro to Bike Park [Italian]
New SCOTT Ransom Enduro Bike in First Test Off to Freedom [German]
New Release Test | SCOTT Ransom 2024: The King Is Dead, Long Live the King [French]
With the 6-Bar, the SCOTT Ransom 2024 Breaks the Ice! [French]
SCOTT Ransom 2024 [German]
New Ransom 2024. SCOTT Has It Ready! [Spanish]
Best Mountain Bikes
11 hours ago
11 hours ago
