SeaSucker Bomber
85/100
We have read all expert and user reviews on the SeaSucker Bomber. In summary, this is what cyclists think.
  • SeaSucker offers this rack in two versions: the two-bike Mini Bomber and the three-bike Bomber.
  • Installation and removal from vehicles is quick and easy, according to testers.
  • Experts and owners say mounted bikes are stable in transit.
  • The Bomber is lightweight and compact.
  • The Bomber fits all common thru-axle and quick-release forks, but adapters must be purchased separately.
  • Each sucker has an orange band that indicates when it's losing suction and requires pumping.
  • SeaSucker sells replacement components, making it easy to swap out worn or damaged parts.
  • The Bomber comes with a strap to stop the cranks moving, and an optional accessory is available for mounting the front wheel to the roof.
4 reasons not to buy
  • Mounting bikes requires removal of the front wheel.
  • The SeaSucker Bomber is expensive for a fork-mount roof rack.
  • A reviewer says balancing bikes one-handed while inserting the axle is tricky.
  • The Bomber only locks to vehicles with an optional low-security cable and shouldn't be left unattended.
SeaSucker's Bomber is a fork-mount roof rack that fixes to vehicles using vacuum suction. The Mini Bomber carries two 45lb bikes; the standard Bomber carries three. Adapters are available for all common fork standards. Experts appreciate the easy installation and removal and the stability of mounted bikes. However, loading bikes can be tricky. The size and low weight make the Bomber ideal for transportation. The rack's suction should be checked frequently. Though expensive, experts feel the Bomber's quality construction makes it a solid roof rack option.
Categories
Rack Type
Maximum Load Capacity
Maximum Weight Per Bike
45 lb
Vehicle Type
12, 17 lb
Material
High-Density Polyethylene (HDPE), Rubber
83/100 based on 3 rated expert reviews
SeaSucker Mini Bomber Roof Rack Review
If you travel a lot and have to rent vehicles but still haul your bike, the SeaSucker rack is in a class all its own.
Cycling Weekly
SeaSucker Mini Bomber Review
It really does stick to the roof of the car…
Review: The Power of Suction Cups? SeaSucker’s Mini Bomber Bike Rack
This isn’t the setup for someone who’s hard on their stuff, either. All that said, if your vehicle doesn’t accept a receiver, and strap-on racks seem a bit hokey, you might be the ideal Mini Bomber owner.
Klein Concept
Trash or Best Bike Rack Ever? Review of the SeaSucker Mini Bomber Suction Cup System.
… I would consider using the SeaSucker again…
84/100 based on 40 ratings
    60%
    13%
    5%
    3%
    20%
Compared to other bike racks
Bike Rack Comparison
SeaSucker Bomber in comparison to averages
