How to Install a Shimano HG or IG Chain
Removal and installation of a Shimano HG or IG chain pin.
In this tutorial, we will learn how to remove and install a connecting pin on a Shimano HG or IG chain. These type of chains always require a special replacement pin that has larger peens.
Tools
For this job you will need a Shimano compatible chain tool such as the Park CT-3, and a set of pliers for breaking the connecting pin after installation. You will also need a black Shimano replacement connecting pin for 6, 7 or 8 speed chains, or a silver pin for 9 speed super narrow chains.
Chain Pin Removal
The first step is to break your chain using a chain tool. If you have previously used a replacement connecting pin, do not disconnect on that pin. The replacement pins can only be used once. Break the chain on any previously unused pin. When you push the pin out, it may be difficult as it will widen the plate holes on its way through. The replacement pins have wider peens to make up the difference. Once removed, discard the old pin.
Chain Pin Installation
When installing a chain, always place the chain in the chain tool grooves furthest from the handle. See the tutorial titled “How to use a chain tool” for more detailed instructions.
Push the replacement pin in with the narrowed end first, then tighten until the narrow end is fully exposed on the other side. The wide end should protrude equally on both sides of the chain.
Now using your pliers, break off the narrow end of the pin. If the link feels stiff, place the chain on the inner grooves of the chain tool closest to the handle, and tighten it just a bit until the link rotates smoothly. For more tips on loosening stiff links, see our tutorial titled “How to loosen a stiff chain link“.
Related Links
Recommended Tools
- Park Tool CT-5 Chain Tool
- Park Tool CT-3 Chain Tool
- Park Tool CC-3.2 Chain Checker
- Park Tool CC-2 Chain Checker
Categories
Rear v-brake repair
Latest post 4 days agoHi everyone, I'm new here and I've been trying to avoid taking my bike to a mechanic and save some money. I succesfully fixed my front but struggle with the rear, I got new brakes for the rear. I notice i think it might be the housing causing the noodle to be off centered and making the left brake pad to close to the rim. Any help would be greatly appreciated, thanks!! My next project is to attemp...
Latest post 4 weeks agoHello, Not sure if I should post this in buying advice or repairs, but here we are. I recently bought Schwinn cruiser an old one and I can't find the rear dropout bracket replacement. So I decided to try out a custom bike part manufacturer. Still waiting for my part, so if anyone has tried out a custom on demand manufacturer, please share your experience....
Latest post 1 month agoI have a Gazelle Esprit belt drive bike with hub gears which has a rear puncture. Can someone advise me on how to remove and refit the wheel? I'm aware that it can be quite complicated, but I have no option other than tackling it myself. The photos were taken with the bike upside down. IMG_20250122_105320.jpg (Size: 77.51 KB / Downloads: 50) IMG_20250122_105428.jpg (...
Read moreGrip Shifters
Read moreTrek domane tyre
Read moreBianchi Oltre Pro Garmin Mount
Latest post 6 months agoI am wondering if anyone can help me with the garmin mount that came with my recently purchased Bianchi Oltre Pro. I was on a ride descending and the mount flew off, landing in the middle of the road with my garmin head unit. Luckily the head unit still works with a few minor scratches and cracks. From the picture you can see that it was not that the screws came loose, it was in fact the part of ...
Read more
