We have read all expert and user reviews on the Specialized Diverge E5. In summary, this is what cyclists think.
11 reasons to buy
- The Diverge E5 comes in three builds: E5 (2x8 Shimano Claris, Tektro mechanical disc brakes), E5 Elite (Shimano GRX 2x10, hydraulic brakes), and Comp E5 (SRAM Apex 1x12).
- Reviewers and owners praise the Diverge E5's value, especially for gravel noobs.
- Experts applaud the versatility of this bike, which comfortably handles everything from smooth tarmac to singletrack.
- A tester relishes the bike's snappy feel on the road.
- The Diverge E5 has clearance for tires up to 47mm wide (700c), or 2.1” on 650b wheels.
- A tester enjoys the extra comfort provided by the Diverge Comp E5’s Future Shock stem suspension.
- The base E5 build’s 46/34t crankset and 11-34t cassette provide ample gearing on and off-road, says a reviewer.
- One reviewer who fits 650b wheels with 2.1” tires praises the bike's handling off-road.
- The performance of the Tektro mechanical brakes (base build) impresses owners and a tester.
- The threaded bottom bracket and lack of proprietary components should simplify maintenance.
- The choice of seven frame sizes from 44cm to 61cm makes it easier to find the right fit.
- The Specialized AXIS Elite Disc wheels and Pathfinder Sport tires aren’t officially tubeless compatible.
- Though the frame has clearance for 700c x 47mm tires, the 21mm inner rim width results in a sub-optimal tire profile with such wide tires.
- The handlebars on the base and Elite builds have no flare.
- The Diverge Comp E5’s Future Shock limits the bar-height adjustability and, on the smaller frames, results in unusually high stack.
- The low bottom bracket lacks clearance for bigger rocks and logs, says a tester.
- One reviewer finds the toe overlap created by fitting 650b x 2.1” tires impedes the steering.
- Owners complain that the stock AXIS Elite Disc wheels aren't durable.
- The base build's Shimano Claris drivetrain requires regular tuning, in one tester's experience.
Specialized’s Diverge E5, an entry-level gravel-adventure bike with an alloy frame and carbon fork, comes in three builds and seven frame sizes. The handling, ride quality, gearing, and brakes impress testers, who also appreciate the tire clearance and abundant mounts for accessories and fenders. When equipped with suitable tires, the bike proves adept at road, gravel, singletrack, and touring. The Comp E5’s Future Shock is a boon for comfort but limits rider fit, especially on smaller frames. Whichever build one chooses, the Specialized Diverge E5’s versatility, performance, and value should leave anyone except gravel purists very happy.Expert Reviews
83/100 based on 2 rated expert reviewsSpecialized Diverge Comp E5 Review – Front End Comfort on the Bike That Promises to Do It All
Specialized’s Diverge E5: A Versatile Gravel Bike That Doesn’t Cost a Fortune
17 hours ago
23 hours ago
24 hours ago
