Specialized Stumpjumper 15
95/100
37.26, 33.73, 29.89 lb
We have read all expert and user reviews on the Specialized Stumpjumper 15. In summary, this is what cyclists think.
15 reasons to buy
  • The Stumpjumper 15 is available in nine builds: three alloy and six carbon, three of which have coil shocks.
  • Experts relish the playful and snappy handling on tight, technical singletrack.
  • All non-coil builds except the entry-level Stumpjumper 15 Alloy have FOX's two-stage air spring Genie shock, which experts find plush, responsive, and easily adjustable.
  • The Genie rear shock and sticky tires help maintain traction on rooty and technical descents and stay planted on climbs, according to testers.
  • Experts say the Genie shock uses its travel so effectively that it feels longer than 145mm, which opens up more aggressive enduro-style descents.
  • The Stumpjumper 15’s composure through the roughest trails impresses expert testers of both the alloy and carbon builds.
  • One tester praises the Stumpjumper Comp Alloy for having comparable ride characteristics to the Pro carbon.
  • Testers say the central seated position and low-slung bottom bracket provide excellent handling in corners.
  • Reviewers appreciate the confidence-inspiring stability afforded by the slack front end and balanced geometry.
  • The Pro (30.84lb) and standard S-Works (29.89lb) builds are lighter than competing top-end trail bikes.
  • The Stumpjumper 15's "dialed-in" geometry makes it comfortable for all-day rides.
  • All frames have internal down tube storage with included tools. A bottle cage mounts to the compartment door.
  • The Stumpjumper 15 frame accepts long-travel dropper posts of up to 213mm in the largest sizes (S5 and S6).
  • The frame allows easy geometry adjustments through switchable headset cups, a chainstay flip chip, and reversible shock mounts.
  • Specialized provides a lifetime warranty on its frames and suspension pivot bearings.
  • Several testers feel the GRID TRAIL tire casing is too thin for this bike. Only the rear tires of the coil shock builds have GRID GRAVITY downhill casing.
  • Owners of medium to large frames (S3-S6) must buy an additional link to mullet the bike. The Stumpjumper 15 Alloy, Öhlins Coil, and S1 and S2 frames on all other builds come standard with mixed wheels.
  • A reviewer says the Industry Nine hub end caps (Stumpjumper 15 Pro) fall out easily when removing the wheels.
  • A tester of the Stumpjumper Pro feels the 32t chainring is limiting on the steepest climbs, preferring 30t.
  • Testers say the bottom bracket height of 337mm (330mm with the flip-chip set to Low) results in limited pedal clearance on chunky ascents.
The Specialized Stumpjumper 15 is a full-suspension trail mountain bike available in six carbon and three alloy builds. This legendary bike is famed as a benchmark in the industry, and the latest iteration maintains that reputation. The bike's composure on rough descents, excellent cornering, and playful, snappy handling on technical singletrack impress experts. The balanced geometry, FOX's Genie rear shock, and easily adjustable geo also earn praise. Complaints highlight the thin tire casing, high gearing, and low BB height. Overall, experts agree the Stumpjumper 15 is among the greatest trail bikes in production, with the alloy builds offering compelling performance at affordable prices.
90/100 based on 3 rated expert reviews
Bike Perfect
I’ve Been Testing Specialized Stumpjumpers for Over 30 Years, but This New Version Is the Most Awesome Stumpy Ever
It packs all the geometry adjust versatility and internal storage practicality of the previous two bikes. It then wraps the whole performance envelopes of what were two very different vibing machines into one shock.
Specialized S-Works Stumpjumper 15 Review: Fun, Versatile and More Capable Than Ever – But I’d Buy the Cheaper Pro Model
The new S-Works Stumpjumper 15 is a seriously capable, fun bike to ride. It’s a plus that it’s so tunable and versatile, making it a real jack of all trades and calling into question how many bikes you might need.
The Beauty of Simplicity Specialized Stumpjumper 15 Review
The Stumpy represents the pulse of the MTB scene. It is the best all-rounder we have ever ridden.
First Ride: The 2025 Specialized Stumpjumper Has a New Dual Chamber Air Shock
… the Stumpjumper 15’s ability to stay composed through very rough terrain is really impressive. The bike also generates a surprising amount of grip for a 145mm bike, putting up strong competition with the longest travel bikes in my garage.
The Loam Wolf
First Ride Review the New Specialized Stumpjumper 15
Though the capabilities are impressive on the new Specialized Stumpjumper 15, it’s the adjustability of both geometry and suspension feel that have been the stand-out in the first couple of days testing.
Mountain Bike Rider
I’ve Tested Every Generation of Specialized’s Full Suspension Stumpjumper, and the Latest Version With the Genie Shock Tech Is the Best Yet
… the new Stumpy is lighter, every bit as stiff and is more capable than before. You also get better seat post insertion, updated SWAT storage, semi-proportional chainstays and a custom-tuned fork… this level of performance comes at a price.
The Ultimate Review of 2025 Specialized Stumpjumper 15 | the Best All-In-One Mountain Bike?
It’s very maneuverable despite it having a 29” rear wheel on the S4. I can still get it through things and features really nicely. it’s a very playful bike, but then it’s also very forgiving.
Flow Mountain Bike
Specialized Stumpjumper 15 Review | a Hugely Adjustable New Trail Bike With a Clever Custom Shock
It doesn’t always make sense to do things differently, but in this case we think it’s paid off. The new Stumpjumper is a brilliant trail bike, and the Genie shock is a big part of that brilliance.
off-road.cc
Specialized S-Works Stumpjumper 15 First Ride Review
The Stumpjumper remains one of, if not, the benchmark trail mountain bikes. It ushers in interesting technology that heightens the experience. It’s an exciting bike.
2025 Specialized Stumpjumper 15 Pro | Specialized What Have You Done? | Test Ride and Review
It has traction, but it keeps it high in the travel when you have it 30% sag on the shock, feels really efficient, doesn’t feel like you’re just bogging down, and it just works.
BIKE Magazine
Follow-up Review: Specialized Stumpjumper 15
It shouldn’t come as a surprise that the new Specialized Stumpjumper 15 is really good. It rides well, can adapt easily to a variety of terrains and riding styles, and the rear suspension feels excellent.
Singletrack World
Specialized Stumpjumper 15 Pro: First Ride Review
The new Stumpy manages to be a customer-pleasing box-ticker (modern geometry, decent dropper insertion, bottle space, frame storage, shorter stem, no thru-headset cable routing) whilst also still being quintessentially Stumpjumper in its capabilities.
2025 Specialized Stumpjumper 15 Pro Bike
The geometry is still spot-on, the frame is stiffer, the frame details are refined, and the on-trail performance is as versatile as ever. Planted, snappy, calm, or lively—it’s a bike with multiple personalities.
Specialized Stumpjumper 15 Pro Review: A Genie in an Air Spring and Adjustable Versatility
With 145mm of rear travel, 29” wheels (as tested), and adjustable geometry, the Stumpjumper is a do-anything, go-anywhere trail bike. The new Genie rear shock is the icing on the cake, enabling this mid-travel bike to handle big impacts…
ENDURO Mountainbike Magazine
New 2025 Specialized Stumpjumper Test – Jack of All Trades?
The integrated riding position and intuitive handling inspire great amounts of confidence, allowing you to negotiate even steep rock slabs without going into panic mode, while the powerful SRAM Maven brakes allow you to control the bike…
Does Specialized’s New Stumpjumper and Its Genie Shock Change Trail Bikes Forever?
… the Stumpjumper is Specialized at its very best. It is a superb, highly refined bike featuring unique ride-enhancing technology in the deceptively simple Genie shock. This bike does everything it is supposed to do and does it extremely well.
Specialized Stumpjumper 15 in comparison to averages
95
