How to Tension Wheel Spokes
Learn how to properly tension the spokes in a wheel.
In this video, we’ll learn how to properly tension the spokes in a wheel. Spoke tension is important to ensure your wheels are strong, reliable and long lasting.
Spokes that are too loose will continue to loosen and require constant wheel truing. Spokes that are too tight will cause damage to the rim, spoke nipples and hub flanges. All of the spokes in the wheel should have approximately the same average tension.
What You’ll Need
For this job you’ll need a wheel truing stand, an appropriately sized spoke wrench and a spoke tension meter. Park Tool makes a simple and affordable tension meter called the TM-1.
Measure Spoke Diameter
To find out what tension your spokes require, you’ll first need to measure the diameter of your spokes. The Park TM-1 tension meter comes with a handy spoke diameter gauge. Use this gauge to find the smallest slot your spokes fit into. If your spokes are butted and have multiple diameters, measure the smallest diameter on the length of the spoke.
Find Required Spoke Tension
Using the tension meter’s included conversion chart, find your spoke diameter and then locate the tension you want to use. Spoke tension requirements will vary depending on the type of rim you have. Lighter rims require less tension, while heavier rims can handle more tension. If you’re unsure, check with the manufacturer of your rim. For this exercise we’ll be tensioning our spokes to 107 kilograms force (kgf), which equals 24 on the spoke tension meter.
Measure Current Spoke Tension
Holding the tension meter horizontally, squeeze the handle and place the spoke between the posts as shown. Then release the handles. Now check the reading on the meter’s scale. You can cross reference this number with the conversion chart to see how many kilograms force your spoke has. As you can see, the tension on our spoke is far too low. Now measure all of the spokes on your wheel, one side at a time. They should all have approximately the same average tension. Due to imperfections in the hub and rim, the tension will rarely be exactly the same for all spokes. A difference of 20% between spokes is acceptable.
Spoke Tension – Front and Rear Wheels
On front wheels the tension should be equal on both sides. On rear wheels the tension will be higher on the right side, or drive side of the wheel. Therefore proper spoke tension should be measured on both sides, but set to the right side spokes of rear wheels.
Increasing Tension
To increase the tension, turn all of the spokes around the entire wheel 1/4 counter clockwise and then measure again. Repeat this step until your spoke tension is within range all the way around. Then true your wheel as explained in the video titled “How to True a Wheel“.
Related Links
Recommended Tools
- Park Tool TM-1 Spoke Tension Meter
- Park Tool SBC-1 Spoke, Bearing, and Cotter Gauge
- Park Tool TS-8 Home Truing Stand
- Park Tool TS-2.2 Home Truing Stand
- Park Tool SW Spoke Wrenches
- Park Tool SW-7 Triple Spoke Wrench
Categories
Rear v-brake repair
Latest post 2 days agoHi everyone, I'm new here and I've been trying to avoid taking my bike to a mechanic and save some money. I succesfully fixed my front but struggle with the rear, I got new brakes for the rear. I notice i think it might be the housing causing the noodle to be off centered and making the left brake pad to close to the rim. Any help would be greatly appreciated, thanks!! My next project is to attemp...
Latest post 3 weeks agoHello, Not sure if I should post this in buying advice or repairs, but here we are. I recently bought Schwinn cruiser an old one and I can't find the rear dropout bracket replacement. So I decided to try out a custom bike part manufacturer. Still waiting for my part, so if anyone has tried out a custom on demand manufacturer, please share your experience....
Latest post 1 month agoI have a Gazelle Esprit belt drive bike with hub gears which has a rear puncture. Can someone advise me on how to remove and refit the wheel? I'm aware that it can be quite complicated, but I have no option other than tackling it myself. The photos were taken with the bike upside down. IMG_20250122_105320.jpg (Size: 77.51 KB / Downloads: 49) IMG_20250122_105428.jpg (...
Read moreGrip Shifters
Latest post 3 months agoMy Trike.jpg (Size: 57.65 KB / Downloads: 49) Wife Trike.jpg (Size: 60.74 KB / Downloads: 49) Although I have ridden bikes on and off since a kid (75 years old now), I have very little experience with anything other than a single speed bike. I recently purchased a new 7-speed Gospel adult tike, which needed assembly. My wife has the same model trike but older and p...
Read moreTrek domane tyre
Read moreBianchi Oltre Pro Garmin Mount
Latest post 6 months agoI am wondering if anyone can help me with the garmin mount that came with my recently purchased Bianchi Oltre Pro. I was on a ride descending and the mount flew off, landing in the middle of the road with my garmin head unit. Luckily the head unit still works with a few minor scratches and cracks. From the picture you can see that it was not that the screws came loose, it was in fact the part of ...
Read more
