Steppenwolf Tundra
78/100
24.0 lb
We have read all expert and user reviews on the Steppenwolf Tundra. In summary, this is what cyclists think.
  • The front suspension fork is equipped with a remote lockout that is operable via a button on the handlebars. This means that it can be turned on or off via the flick of a switch.
  • The Avid disc brakes use mineral oil which means less bleeding is needed, due to the fact that no water and air are entering the system.
  • The aluminum frame on the 27.5” model was considered to be light - while the 29er's featherweight carbon frame floated on a higher level.
  • Experts and amateurs alike, painted the geometry of the Tundra as ‘racy’. In general, it was described as a ‘very fast’ bike.
  • Some buyers thought the price was almost too good to be true. An expert rated the ‘price-performance ratio’ as very decent.
  • According to reviewers, photos can not do the Tundra justice. In person, it was depicted as being a great looking machine with a modern design.
  • Users say that gears shift smoothly straight-out-of-the-box, with no need for adjustment.
  • This handling on this rig is apparently very responsive.
  • The Tundra accommodates wide tires, up to 2.5 in the front, by some reports.
  • Componentry is generally considered to be of high quality: including DT Swiss rims, Easton or FSA Bars, FSA or SRAM Crankset, Shimano XT Drivetrain and Avid Brakes (according to specific model).
4 reasons not to buy
  • One expert felt that the fork on the 27.5 model could be upgraded, but this wasn’t seen as a major drawback.
  • On the same model, this expert felt that the brake calipers were not of the highest quality.
  • Some riders swapped the Ergon saddle out fairly early. This might be a sign that it wasn’t the most comfortable.
  • One user lamented the Tundra’s lack of rack mounts.
There weren’t a lot of criticisms leveled against the carbon 29” model of the Tundra. Owners felt that it was a steal at the given price. While the aluminum 27.5” model is obviously fit out to be more affordable than its carbon cousin, there were some compromises in key areas (shocks, brakes), that led to experts rating it as less-than-perfect. In general, the engineering and componentry impressed – and led to a memorably agile ride.
87/100 based on 19 ratings
    63%
    32%
    5%
#109 Best Mountain
Bottom 20%
#27 Best Cross Country
Bottom 20%
#657 Best of All Bikes
Bottom 30%
Steppenwolf Tundra in comparison to averages
