Thule Passage
80/100
If you find a lower price, email us at contact@bikeride.com with documentation of the price. We’re committed to making sure that the cost of a bike does not keep you from cycling!
We have read all expert and user reviews on the Thule Passage. In summary, this is what cyclists think.
5 reasons to buy
  • Buyers and experts say the rack to vehicle connection is secure.
  • The bikes stay steady, even on bumpy surfaces and in stop-and-go traffic, according to reviewers.
  • The rack arms fold when not in use, reducing the rearward protrusion from roughly 22” to 10”.
  • An expert and buyers appreciate the removable anti-sway cradles that help prevent bikes from bumping the trunk or each other.
  • The foam tubes that rest on the vehicle protect the paint and glass.
  • This rack isn’t compatible with many mountain bikes, kids’ bikes, or step-through bikes. Reviewers say it’s best for horizontal top tubes.
  • Experts and buyers complain of a tight fit, saying the bikes sit very close together. Most suggest the three-bike rack for transporting two.
  • Vans, hatchbacks, and SUVs cannot use the rear windshield wiper with the rack installed.
  • One expert says that the rack isn’t compatible with most hatchbacks. Users with hatchbacks confirm this incompatibility.
  • An adapter (purchased separately) is required for step-through bikes, and one expert says it doesn’t work very well.
  • License plates may be blocked when bikes are mounted.
  • There is nowhere to tuck the excess strap material after tightening them.
The Thule Passage is a trunk bike rack available in two and three-bike versions. It holds bikes securely in place and the no-sway cages prevent bike-to-bike contact during transport. The main complaints include incompatibility with certain bikes, particularly mountain and kids’ bikes, and not enough distance between mounted bikes. Potential buyers should verify rack-to-vehicle compatibility before purchasing, especially hatchbacks. The Passage is a decent rack for the price, and experts say it’s great when it works. However, it has limited vehicle and bike compatibility. As an alternative, consider the Saris Bones trunk rack.
Rack Type
Maximum Load Capacity
Maximum Weight Per Bike
35 lb
Vehicle Type
9.7, 10.8 lb
Material
Alloy Steel, Foam
76/100 based on 2 rated expert reviews
Two Wheeling Tots
Thule Passage Bike Rack Review
… the Thule Passage doesn’t fit every car or accommodate every bike, but if you are lucky enough to have the Thule Passage work for you, you won’t be disappointed.
Frugal Average Bicyclist
Thule Passage 2-Bike Trunk Rack Review
If you have the right bikes, it’s a pretty good deal, but it’s very limiting.
Life with the GeeFam
Thule Passage 3-Bike Rack eTrailer | Unboxing
… I think a regular-size [bike] or a regular-sized mountain bike will do…
77/100 based on 282 ratings
    53%
    13%
    11%
    10%
    13%
Bike Rack Comparison
Thule Passage in comparison to averages
