Tumbleweed Chromoly T Rack
88/100
Categories
Weight Capacity
30 lb
Fits Wheel Sizes
Disc Brake-Compatible
1.43 lb
Material
Chromoly Steel
We have read all expert and user reviews on the Tumbleweed Chromoly T Rack. In summary, this is what cyclists think.
7 reasons to buy
  • The Chromoly T Rack comes in two heights to accommodate different wheel sizes and tire widths.
  • Though heavier than aluminum, steel construction is considered more durable and easier to repair, making it the preferred choice for extended journeys, particularly away from developed areas.
  • The Chromoly T Rack can be mounted front or rear.
  • One expert says the rack has had no issues after “thousands of miles”, and another says it withstands riding rough terrains.
  • The rack has three-pack mounts on each side of the main struts.
  • The Chromoly T Rack has a port for dynamo wires, but Tumbleweed doesn’t provide clear details about it.
  • This rack is compatible with dropper seatposts.
2 reasons not to buy
  • Tumbleweed’s written instructions are vague and imageless, and there are no installation videos.
  • This rack doesn’t have a deck.
Tumbleweed’s Chromoly T Rack is a front or rear-mount cargo rack with a 30lb load capacity. It comes in two heights: 355mm or 380mm, and requires rack mounts for installation. Testers praise the Chromoly T Rack’s durable Chromoly steel construction and versatility for carrying smaller items. This rack has a port for dynamo routing but no deck. The higher weight compared to aluminum alternatives should be noted. Installation instructions are underwhelming. Overall, experts like the Chromoly T Rack and find little to complain about. For carrying larger bags, consider Tumbleweed’s Pannier Rack instead.
88/100 based on 2 rated expert reviews
Move with Murph
The Line Between Bikepacking, and Bike Touring | The Tumbleweed T RackThe Line Between Bikepacking, and Bike Touring | The Tumbleweed T Rack
Having something purpose-built for bikepacking that can withstand rough terrain but also has the capability of carrying heavier, larger loads as more of a touring setup… [is] the best of both worlds.
Bikepacking.com
Tumbleweed Racks Review: T Rack and Mini Pannier Rack
What separates these racks from most others on the market is that they each come with a three-pack of threaded mounts on both sides. They also each come in two different lengths for bikes of different sizes.
Bike Rack Comparison
Tumbleweed Chromoly T Rack in comparison to averages
