We earn affiliate commission.
Learn more
Type
6, 8 Hours
80 Miles
30 mph
2000 W
104 Nm
50.4V 41.67Ah,
50.4V 61.51Ah
50.4V 61.51Ah
140.2, 151.2, 144.6, 155.6 lb
We have read all expert and user reviews on the UBCO 2x2. In summary, this is what cyclists think.
26 reasons to buy
- UBCO’s 2x2 can carry a 330 lb payload, including rider and cargo.
- With a motor in each wheel, the 2x2’s traction is increased on wet surfaces.
- The 2x2 Adventure is road-legal and ready to be registered for urban use.
- With no gears, the 2x2 is easy to ride, even for novices.
- Range-anxiety is annihilated by the 2x2’s 80-mile potential, from one charge.
- The 2x2 Adventure’s handling and ride quality is said to be great on and off-road.
- An impressive 90Nm of torque is delivered by each of the 2x2’s motors.
- The UBCO 2x2’s trellis frame incorporates sturdy front and rear racks.
- The 2x2 features a steering lock and lockable battery.
- If owners opt-in, they can track and trace their 2x2 using GPS location.
- The 2x2 Adventure is equipped with bright, integrated front and rear lights, in addition to brake, number plate and directional lights.
- The 2x2’s battery is positioned low to provide a stable center of gravity.
- 2x2 models are lightweight for a motorbike, starting at 140.2lb.
- The 2x2’s near-silent motor makes it well-suited to hunting and herding.
- Reviewers said the 2x2 felt very sturdy, loaded-up, or empty.
- The 2x2’s regenerative brakes conserve battery power.
- UBCO’s app gives 2x2 riders detailed information on settings, motor temperature, brake usage and GPS tracking.
- The 2x2’s Tektro hydraulic disc brakes prove plenty powerful.
- The 2x2 is furnished with a 12-month warranty on the bike and accessories, in addition to a 24-month warranty on the power supply.
- A small trailer can be hooked up to the 2x2, for towing hunted prey or cargo.
- The 2x2’s battery features a 12V outlet and USB ports to power tools and devices.
- The 2x2’s LED display shows battery level, speed, trip distance and warning or error messages.
- The 2x2 has no clutch or drivetrain, making maintenance and operation simple.
- The 2x2’s 130mm front and 120mm rear suspension handles urban riding with ease.
- The 2x2 is fitted with a sturdy, stable and well-placed kickstand.
- The 2x2 uses a 10 amp charger that reaches full charge in 6 to 8 hours.
- Some reviewers saw the 2x2 as expensive.
- With 2.4kWh or 3.2hp of power, some reviewers said the 2x2 felt ‘underwhelming’.
- Under offroad use, one reviewer said the 2x2’s suspension was easily “overwhelmed”.
- One owner experienced faults with the 2x2’s display and clock.
- The same owner complained of poor communication from UBCO.
The UBCO 2x2 is a lightweight electric motorbike fitted with a hub motor in either wheel. UBCO stands for ‘Utility Bike Company’ so you can expect the 2x2 to be a practical machine. The bike comes in two sub-models: ‘Adventure’ and ‘Work’. The Adventure model is road-registerable and comes fitted with a digital display, horn and turn signals. Its tires are suited to pavement and dirt. The bike comes with an app that offers additional settings and readouts for motor temperatures and regenerative brake usage. It isn’t intended for thrashing, but is more of a steady ride. The 2x2 is generally seen as a well-thought-out and cleverly designed bike that can haul cargo and work a farm or ranch. The estimated cost of charging to full power is less than 73¢. Battery capacities are available in 2.1kWh and 3.1kWh options.Expert Reviews
70/100 based on 1 rated expert reviewUBCO 2×2 Review: Mountain Goat
UBCO 2×2 – Electric Bike Workhorse
Ode to the Honda CT-90 | UBCO 2×2 Electric Motorcycle
UBCO 2X2 Electric Bike | First Ride Review
10 Things You Want to Know About UBCO 2×2 5th Generation
UBCO 2X2 Test Ride, Review, and Interview with UBCO US CEO
UBCO 2×2 Electric Utility Bike – Honest Review
UBCO 2×2 Utility Bike 2WD Review
UBCO 2×2 Ebike Review
Ubco 2X2 First Ride Review
UBCO 2×2 Adventure Bike Review: Utility That Shreds
NZ-Made: UBCO 2×2
UBCO 2×2 Off-Road Electric Bike Review
Review: UBCO 2×2 Electric Bike
Now, Something Totally Different: Riding the UBCO 2×2 Electric Trail Bike
Review: UBCO’s Electric Two Wheel Drive Bikes Prove Viable Alternative to Petrol Power
New Zealand Military Battle-Lab Tests UBCO 2WD E-Motorcycle
Electric, 2×2 and Riding UBCO’s Utility Bike
On Test: Can UBCO’s Electric Bike Compete With ATVs?
UBCO 2×2 in comparison to averages
8 hours ago
8 hours ago
15 hours ago
