Vitus Dominer
80/100
38.6 lb
We have read all expert and user reviews on the Vitus Dominer. In summary, this is what cyclists think.
13 reasons to buy
  • The Vitus Dominer is a downhill-specific bike. It has 200mm of travel in the front and rear.
  • Wide 780mm-800mm Nukeproof handlebars provide riders with stability on descents.
  • Vitus makes the bike compatible with a coil or air shock.
  • The long reach on the Dominer gives riders the ability to shift their weight for greater control and stability.
  • Testers found it easy to fine-tune the suspension setup with both a fork and shock from RockShox included in each build.
  • Maxxis tires offer riders plenty of traction for descending loose or wet trails.
  • The threaded bottom bracket is easy to maintain.
  • The Dominer is more affordable than other downhill bikes.
  • Vitus includes a chain guide tab to keep the chain on track riding rough terrain.
  • The bike is set up tubeless-ready. This allows riders to run lower pressures and prevents frequent flats.
  • The SRAM brakes are extremely responsive and work well.
  • Sizes small through extra-large allow most adult riders the ability to utilize this downhill shredder.
  • Vitus specs the Dominer with a 7-speed SRAM or 10-speed Shimano downhill-specific drivetrain.
4 reasons not to buy
  • The Vitus Dominer’s frame does not have a protective finish. The frame can easily become damaged.
  • The bike is heavy at almost 40lbs.
  • Testers experienced kickback in the rear with the coil shock build.
  • Chain slap occurred frequently on the Dominer.
The Vitus Dominer is a downhill-specific beast. It is affordable with an aluminum frame. Vitus uses Nukeproof's saddle, handlebars, and stem on it. The bike is heavy at over 38lbs. All builds come with a downhill-specific drivetrain. The bike does well to cushion blows from drops and rough terrain. Some experts note kickback can be an issue when riding the bike with a coil shock. Chain slap is another annoyance testers identified on the bike, despite Vitus's inclusion of a chain guide.
80/100 based on 1 rated expert review
Vitus Dominer Review
Like most DH bikes in this price bracket, the frame is made from 6061 aluminium alloy.
RideWithSharn
My Casual Attempt at a Vitus Dominer DH Downhill Bike Zee Review + Some Specs
I’m really happy with this bike.
93/100 based on 3 ratings
    67%
    33%
Vitus Dominer in comparison to averages
