important: Nuts and bolts on your bike should always be tightened to the manufacturer's specifications.
How to True a Wheel
Aspects of wheel truing covered include radial, lateral, centering (or dishing) and spoke tension.
Wheel truing is a delicate procedure that requires time and patience. In this tutorial I’ll try and demonstrate the many aspects as clearly as possible. Ideally you’ll want to have a wheel truing stand, good lighting and a comfortable workspace.
Wheel Truing Tips
If you don’t have a truing stand, lateral, or side to side adjustments can be done using your brake pads as a guide. If truing the wheel on your bike, be sure to deflate the tire before you begin. For radial, or up and down adjustments, you can use an L-square as a guide by attaching it to your fork or frame.
It is very important to use the correct size spoke wrench to avoid stripping the spoke nipples.
Before you begin, carefully inspect your wheel for any bent or broken spokes. Make sure your hub bearings don’t have any play and then carefully squeeze a drop of light oil into all of your spoke holes.
Spoke nipples have a regular right-hand thread, but that while you’re truing a wheel, you will be looking at the nipple upside-down, so you have to turn the spoke wrench clockwise to loosen and counter-clockwise to tighten.
Make sure the spoke doesn’t turn with the nipple, which will cause it to twist and break. If it does turn, apply some light oil to the nipple threads and try again.
If a spoke does break while you’re truing, it’ll shoot out the spoke hole with great force, so be careful not to place your face in line with the rim. Safety glasses are highly recommended.
Radial (Vertical) Adjustments
To check radial alignment, place the guide near the highest point on the outer edge of your rim. Find the high spots in your rim by spinning the wheel and correct them by tightening both left and right side spokes evenly. Correct any low spots by equally loosening the spokes in the effected area.
Tighten or loosen spokes in 1/4 turn increments. For example, if the effected area spans the length of four spokes, tighten all four spokes 1/4 turn, and then tighten the middle two spokes another 1/4 turn. Then re-check the radial alignment and repeat the process as needed.
Lateral (Side to Side) Adjustments
To check lateral adjustment, place the guide close to the rim sidewall and look for high spots on either side. To correct a left or right high spot, tighten the spoke that leads to the opposing hub flange and equally loosen the spoke that leads to the hub flange on the same side as the high spot.
Just like radial adjustments, tighten or loosen the spokes in 1/4 increments. Again if the effected area spans four spokes, loosen and tighten all four spokes 1/4 turn, and then loosen and tighten the middle two spokes another 1/4 turn.
Re-check the lateral alignment and re-adjust as needed. Remember that on the rear wheel, the right side spokes have a lesser angle and effect lateral movement less than the left. The left side spokes have greater angle and effect radial alignment less than right. To compensate for this difference, the right side spokes should be adjusted two turns for every turn on left.
Centering (Dishing)
Rims should be exactly centered between the axle nuts. To check this you can use either a dishing tool, or your frame to check the measurement on each side.
If the rim is off-center, pull it in either direction by equally tightening all of the spokes on one side 1/4 turn, and loosening all of the spokes on the other. Then check the alignment again and repeat the process until the rim is centered.
Spoke Tension
To check spoke tension, pluck each spoke in the middle and listen to the sound. On the front wheel, all of the spokes should sound the same on both sides. On the rear wheel, each side should sound slightly different, but the spokes on each side should sound the same as each other.
Most people don’t have a spoke tensiometer, so it’s a good idea to compare the sound of your spokes to the sound of a wheel that you already know has proper tension. Remember that spoke changes effect the whole wheel, so you might have to repeat these steps several times before it is true.
Stress-Relieving Spokes
After the wheel is true you should always pre-stress the spokes and re-adjust before riding. Failure to do this could cause broken spokes later. There are two ways to do this. The first way is to squeeze together the parellel spokes on both sides of the wheel. The second method involves resting the wheel sideways on the floor and gently pushing down on both sides of the rim, all the way around the wheel in 1/8 increments.
After pre-stressing the spokes you will usually have to re-check and make some minor adjustments. If after stressing the wheel you notice that your rim is severly warped, it means that your spoke tension is too high. Loosen all of the spokes 1/2 turn and re-true the wheel.
Related Links
Recommended Tools
Categories
Rear v-brake repair
Latest post 1 day ago
Hi everyone, I'm new here and I've been trying to avoid taking my bike to a mechanic and save some money. I succesfully fixed my front but struggle with the rear, I got new brakes for the rear. I notice i think it might be the housing causing the noodle to be off centered and making the left brake pad to close to the rim. Any help would be greatly appreciated, thanks!! My next project is to attemp...
Read more
Custom Bike part manufacturing
Latest post 3 weeks ago
Hello, Not sure if I should post this in buying advice or repairs, but here we are. I recently bought Schwinn cruiser an old one and I can't find the rear dropout bracket replacement. So I decided to try out a custom bike part manufacturer. Still waiting for my part, so if anyone has tried out a custom on demand manufacturer, please share your experience....
Read more
I have a Gazelle Esprit belt drive bike with hub gears which has a rear puncture. Can someone advise me on how to remove and refit the wheel? I'm aware that it can be quite complicated, but I have no option other than tackling it myself. The photos were taken with the bike upside down.   IMG_20250122_105320.jpg (Size: 77.51 KB / Downloads: 49)   IMG_20250122_105428.jpg (...
Read more
Hi everyone! I hope you're enjoying a great start to 2023. I'm curious to hear your go-to method for getting a chain truly clean. I don't mean, just looks shiny or is good enough for a quick clean after a ride. I want to know what you do when you want to get every last morsel of ground-up, link-destroying, roller-eating, tooth-gnashing crud out of your chain. The Best Chain-Cleaning Recipe Ever?...
Read more
What jockey wheel Red 10 Speed
Latest post 2 months ago
Can anyone advise what type of replacement jockey wheel I need for a 10 speed Red rear mech (it's got 11 teeth)? Bonus points if it's a link to a cheap (ish) one! Thanks...
Read more
Grip Shifters
Currently renovating a child's bike. It has 24 inch wheels and is a suitable size for a 7-10 year old. Anyway it has grip shifters. it is a six speed with three chain rings on the front derailleur. On the rear derailleur the shifter does not appear to move the gear cable at all when shifting from 6 to 5 and 5 to 4. I am actually holding the cable with my finger and thumb against the cable cas...
Read more
9 speed chain on 8 speed bike
All of my bikes are 7 or 8 speed and sometime in the past I bought a 9 speed chain for some unremembered reason. is there any reason not to use it on an 8 speed bike?...
Read more
Operation of Santa Monica Ebike
Latest post 3 months ago
Hello - new owner with an How to Operate the bike question. Hopefully, this is easily answered I Bought this bike a few weeks ago - Tested many bikes and finally landed on this particular Santa Monica. However, got busy with Christmas shopping, Life, and not so great weather days distracted me from riding. I also test drove so many that I forgot how to operate it.... I "thought" I remembered, ...
Read more
Gears and derailleur misalignment
  My Trike.jpg (Size: 57.65 KB / Downloads: 49)   Wife Trike.jpg (Size: 60.74 KB / Downloads: 49) Although I have ridden bikes on and off since a kid (75 years old now), I have very little experience with anything other than a single speed bike. I recently purchased a new 7-speed Gospel adult tike, which needed assembly. My wife has the same model trike but older and p...
Read more
I'm curious—how often or after how many miles do people typically check or change their mechanical disc brake pads? I've been bikepacking for a while but never really followed a maintenance schedule. A few weeks ago, I took my bike to a mechanic because I heard some noise. The mechanic did a quick overhaul, and I was sent on my way. However, a few weeks later, while descending steep hills, I s...
Read more
Shifting is almost impossible
Latest post 4 months ago
My wife's road bike has Shimano Sora shifters with a triple front derailleur (stock). The thumb switch on the front shifter is VERY hard to use and she can't do it when she's riding. I did a full adjustment of the front derailleur but it didn't change anything. One thing that I noticed is that the shifter works smoothly when the shifter cable is unattached from the derailleur, suggesting that the ...
Read more
7-speed bicycle with bent rim
Latest post 5 months ago
I recently bought a 7-speed bicycle practically brand new it still has a little rubber nipples on the tires apparently it got backed into in the garage and it bent the rear rim sideways my question is can I go out and buy another just like single speed 20 inch bicycle and put the 7-speed cassette onto that rim?...
Read more
Trek domane tyre
Hi I have a trek domane 2.3, and I have changed the rear tyre to 28 (it was 25 originally) The tyre rubs with the brake arm (v brake), I fear it doesn’t seem to be compatible Is there any way to adjust the position of the brake arm? I just need it to ne around 2mm higher Thanks...
Read more
Schwinn meridian rear drive axle
Recently bought a slightly used 26" meridian trike. While replacing wider tires on the rear, I noticed an issue with the rear drive side wheel hub. The wheel is held on with a nut and single washer. The hub is not held firmly in a location on the axle and is able to slide back and forth on the axle a good half inch even though the nut is tightened all the way down to its bottom threads on the axle...
Read more
Bianchi Oltre Pro Garmin Mount
Latest post 6 months ago
I am wondering if anyone can help me with the garmin mount that came with my recently purchased Bianchi Oltre Pro. I was on a ride descending and the mount flew off, landing in the middle of the road with my garmin head unit. Luckily the head unit still works with a few minor scratches and cracks. From the picture you can see that it was not that the screws came loose, it was in fact the part of ...
Read more
