We have read all expert and user reviews on the Yakima HangTight. In summary, this is what cyclists think.
7 reasons to buy
- The Yakima HangTight comes in four and six-bike versions.
- Testers agree that the rack keeps bikes secure during transit.
- The rack has a tilt feature for accessing trunks. This can’t be used with bikes mounted.
- The HangTight holds most bikes without requiring additional accessories.
- Ample spacing between bikes prevents pedal interference, say testers.
- Top tube adapters aren’t required for step-through bikes as bikes are clamped at the bars, unlike other verticle hanging racks.
- Yakima’s DH Cradle (purchased separately) expands compatibility to downhill MTBs.
9 reasons not to buy
- The four-bike HangTight only fits three drop-bar bikes; the six-bike version fits just four.
- The HangTight requires a minimum tongue weight capacity of 250lb.
- This rack isn’t compatible with 1.25” hitches, RVs, trailers, or campers.
- Testers bemoan the time-consuming assembly and installation.
- This rack isn’t compatible with aero bars, clip-on aero bars, or handlebars with a diameter above 35mm.
- When used off-road, the total capacity drops, supporting 42.5lb on the two center cradles and 22.5lb on the outer two or four.
- The HangTight is heavy, bulky, and doesn’t fold down.
- Experts and buyers say the rack wobbles slightly at the hitch, though this doesn’t cause bike-on-bike interference.
- A 15/16” (24mm) wrench is required for installing the hitch pin.
The Yakima HangTight is a hanging hitch rack available in four or six-bike versions. Compatibility includes 20” to 29” wheels, 50” wheelbases, and 5” tires. The rack is best for transporting flat-bar bikes as capacity is reduced for drop-bar bikes. Compatibility with drop bar variations and short stems (below 40mm) is also limited. Weight capacity is lower when driving off-road. Owners and testers complain about the wobbly hitch, lengthy installation time, high weight, and bulk. Vehicle compatibility is relatively limited, and potential buyers should consider their hitch’s ground clearance. Nonetheless, the HangTight is deemed a solid, secure option for transporting several flat-bar bikes.BikeRide finds and shows you the best prices of the bikes you want to buy. Prices constantly change and it’s impossible to compare them all yourself.
73/100 based on 3 rated expert reviewsYakima HangTight 4 Review
Review: Yakima HangTight 4 Hitch-Mount Bike Rack Is a Sturdy, Strong Choice
Yakima HangTight 6 – Vertical Bike Rack Review
Review – Yakima HangTight 6 Vertical Bike Rack
Review: Yakima HangTight 6
Tested: Yakima HangTight 6
Best Bike Vehicle Racks
Bike Rack Comparison
6 hours ago
19 hours ago
