We earn affiliate commission.
Learn more
Type
27.62, 28, 29.19 lb
We have read all expert and user reviews on the Yeti SB115. In summary, this is what cyclists think.
18 reasons to buy
- The SB115 is a short travel trail bike that is capable of long days in the saddle and multi-day stage races.
- Experts were pleased with the bike using the Switch Infinity suspension setup. With 115mm of rear travel, it offers support and cushioning over a variety of trails.
- A short seat tube allows for a longer dropper post.
- The geometry of the bike places riders in a balanced position for railing through berms.
- Tight, technical climbs and descents are easily maneuverable with the nimble handling of the SB115.
- Cables are cleanly routed with tube-in-tube pathways through the frame.
- Testers found there was minimal pedal bob when climbing. There is no need to lock out the shock on most climbs.
- The suspension has three adjustments: open, closed and trail mode. Switching between these allows riders to adjust the suspension to their riding terrain.
- Boost spacing and the Switch Infinity suspension system offer riders efficiency for climbing.
- Yeti uses a Maxxis Aggressor tire in the rear and a Minion DHF tire up-front. These excel on the type of hardpack trails found in the western United States.
- Four sizes, ranging from small to extra large, provide numerous riders with a size of the SB115 that suits them.
- The carbon frame is beautiful and durable, according to experts.
- Yeti offers the bike with Shimano or SRAM components.
- There is plenty of room for a full-size water bottle in the frame.
- The suspension setup offers fantastic small bump compliance. It floats over rocky and rooty trail sections.
- ISCG tabs are included, allowing riders to use a chain guide.
- A fender over the shock keeps it clean and free of debris.
- 780mm handlebars are wide and offer riders stability on trails.
4 reasons not to buy
- The bike is heavy. Even the small size weighs 27lbs.
- Yeti ask a high price for the SB115.
- The press-fit bottom bracket is not as easy to maintain as a threaded bottom bracket.
- Riders shorter than 5’1” can not use the bike. There is no extra small size.
The Yeti SB115 is a short travel trail bike. It has 115mm of travel in the rear and 130mm upfront. Testers describe the bike as a down-country bike that can take on multi-day stage races. It has room for a full-size water bottle. Technical climbs and descents are a breeze on it, despite its hefty weight of 27 lb or more (depending on size). The carbon frame is clean and neat with internally routed cables. The bike is not cheap, with builds including high-quality SRAM and Shimano components. With sizes small through extra large, most riders above 5’1” will find a size that suits them.Expert Reviews
71/100 based on 2 rated expert reviewsHead to Head: Transition Spur vs. Yeti SB115 Bike Review
Yeti SB115 TURQ3 in Review – A Motorless Rocket
Field Test: Yeti SB115 – The One That Wants to Be a Trail Bike
Yeti Cycles SB115 Test Ride & Review
2021 Yeti SB115 Review | So Nearly the Ultimate XC/Trail Mountain Bike
Yeti SB115 T1 First Ride Review
Slice Trails on the Lively and Precise Yeti SB115
Yeti SB115 | Review and First Ride Impressions
Yeti SB115 C1 Review. More Down Country MTB Than XC
Bible Review: Yeti SB115 T2 Turq $____
Yeti SB115 Mountain Bike Review: ‘Down-Country’ 29er Slays Ups and Downs
The Yeti SB115: A Cross-Country Bike for Riders Who Get Rowdy
Yeti SB115 T1 in Review – Uphill Efficiency Meets Downhill Fun!
First Ride: The New Yeti SB115 Mountain Bike
Best Mountain Bikes
Yeti SB115 in comparison to averages
8 hours ago
11 hours ago
14 hours ago
